Progressive Insurance
britishcustomsMotorcycle.com Classifieds!britishcustomsShopTriumph.comSportbikeTrackGearMotorcycle.comAdvanstarMotorcycleShowsAmericanMotorcyclistAssociationTriumphPerformanceUSAAnnitori Distributing
CycleGear.com
Old 10-24-2005   #1 (permalink)
Has anyone else noticed that the turn signal switch shorts out in the rain? Each time I've ridden in the rain I lose my blinkers, and I have to give the switch a shot of WD-40 to get them back. I'm planning on opening up the control cluster and slathering it with dielectric grease.
Myrddraal is offline   Reply With Quote
Old 10-24-2005   #2 (permalink)
ST
ST's Avatar
Are you sure its just the switch and not the exposed plug conectors at the front of the bike below the headlamp area?
My alarm played games on me when i washed the bike a while back and i could never trace the fault. Dealer sprayed water repellant over most of the connector blocks and ive not a had a problem since...
may be worth a look.
ST is offline   Reply With Quote
Old 10-24-2005   #3 (permalink)
That could be too. I'll grease up the entire thing, just to be sure.
Old 10-25-2005   #4 (permalink)
Favorite Bike: 2003 Sprint ST
Since the bike is new I would take it to the dealer, if he's not too far. In any case give him a heads-up and tell him what you will do. Just to assure that you don't mess-up up your warranty.
SpiderTex is offline   Reply With Quote
Old 10-25-2005   #5 (permalink)
Retired Legend
DaveM's Avatar
Other Motorcycle: Not yet
Myrddraal,
what type of shorts was the switch wearing to start with?
Sounds like maybe they were the ones with the prince of darkness prints on them.(Mr Lucas from way back)
The correct shorts your switch block should have on have a Triumph emblem stamped on them.
Rule No one with electrics ... check you are wearing your shorts! :hammer:
Hope this is helpful.
:-D
davem
Old 10-25-2005   #6 (permalink)
ST
ST's Avatar
DaveM...... im confused :???: or have you been on the xxxx
turn signal switch has a gremlin AJF1134 Twins Technical Talk 6 09-05-2007 06:09 PM
Repair turn signal switch? kevdude70 Classic, Vintage & Veteran 2 07-24-2007 07:46 AM
Right turn signal out raff Twins Technical Talk 10 05-25-2007 10:33 AM
Wet Flasher relay? Turn signal stays on after rain/wash. '04 RS Sprint Forum 4 06-15-2004 01:23 PM
Turn Signal Daytona Deliberations 3 05-01-2002 09:58 PM
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
