On 2005-10-08 20:06, REGULATOR wrote:
does anybody use one on the Sprint?
I use Gerbings, and have the jacket liner and gloves. Work great. I've yet to pull 'em out on the "new to me" Sprint, but don't anticipate any issues, since the Sprint's alternator puts out more current than my Road King does. The jacket draws 77 watts (at full) and the gloves another 22 watts. At 13.8 volts (12v nominal) that equates to 7.17 amps. The liner alone would pull just 5.57 amps. I don't usually run the stuff much higher than half way (I have a "temptroller").
The socket is on the circuit protected by fuse #3, which is a 10a fuse. Other things on that circuit are heated grips (which you say you have). Running just the jacket liner, you'd have no problem I would think.
