Sprint carbon canister vacuum connection - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 07-09-2011, 11:31 PM Thread Starter
Main Motorcycle: 2013 Tiger Explorer
Other Motorcycle: 70 Commando cafe
I was poking around the Sprint GT and noticed a line coming from the carbon canister was not connected to anything. It's the vacuum pipe with the U bend on the end shown in the attachment. The diagram on the bikes air box shows it connects in the area of the middle throttle body. I've pulled off the air box and checked all around but for the life of me I can't find any unused connections anywhere.
Would somebody with a canister equipped bike mind looking letting me know where it goes? This may solve the little off idle stumble I've been having lately.
littlefield is offline
post #2 of 6 (permalink) Old 07-10-2011, 12:31 AM
Main Motorcycle: 2006 Sprint ST ABS
champ87's Avatar
Other Motorcycle: 1973 Yamaha RD350
Extra Motorcycle: 1974 Kawasaki 500 H1E
The middle cylinder has 2 connections - the one going to the T-piece is the MAP connection. The other controls the vent valve on the canister via the vacuum pipe.
Look closely at the pic below. The left connection on the middle throttle bore routes between the manifolds and drops down behind the throttle bodies.
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline
post #3 of 6 (permalink) Old 07-10-2011, 10:34 AM Thread Starter
Odd. Mine is not like that. As I recall, my 07 Tiger with no canister also had the second port on the middle throttle body capped off. Wonder if the line has ever been connected? I reckon they're all the same but if anybody with a 2011 can take a gander I'd appreciate it.
Name:	vaccum lines.jpg
post #4 of 6 (permalink) Old 07-10-2011, 01:05 PM
Main Motorcycle: '15 Street Triple R
Extra Motorcycle: '70 Husq 360 cross
There are 3 hoses on the carbon canister, two hoses are about 3/8" ID. and 1 is about 1/4" dia.
The 1/4" hose(has tip of pencil just behind it) is the one we are talking about.
When the bike is started, a vacuum is applied to the 1/4" hose, which opens the vent valve on the CC.
If this hose is disconnected, you have a vacuum leak somewhere and this surely will cause a off-idle stumble.
Just for info: The upper center- left 3/8" hose goes to the fuel tank tip-over valve. The 3/8" hose to the right wraps around the front of the CC and connects to the purge valve, which is mounted between the cylinder block and the front of the CC.
I would think Champ's '07 is the same as the later Sprints, but you can use "search" for "vacuum line diagram" and look at every post.
Bruce C is online now
post #5 of 6 (permalink) Old 07-10-2011, 02:07 PM Thread Starter
Champ and Bruce,
Thanks both of you guys for responding. I'm assuming my vacuum line was not attached at the factory. I'll remove the plug on the second port by the middle throttle body and connect the vacuum line there.
post #6 of 6 (permalink) Old 11-25-2012, 11:16 PM
Main Motorcycle: 2011 Sprint GT
Other Motorcycle: 1982 Honda CB750SC
Interesting as I've just noticed today I may have the same issue, the vacuum hose end of the evap canister that looks like it's disconnected. Bike is running just fine, no check engine light, no stumbling. I haven't pulled the tank yet to get a closer look; littlefield did you connect your hose as mentioned above and what was the outcome? P.S. My bike is a U.S. bike (Kentucky)
Tom
tomfromON is offline
Fuel pressure regulator vacuum hose connection Patman1200 Tiger's 885i & 955i - Mods & Workshop 18 03-10-2012 02:30 AM
Do all '08 Sprints have a carbon canister? StAddict Sprint Forum 9 06-10-2008 03:35 PM
Vacuum Canister BBDGriptonia Triumph SuperSports 4 03-22-2007 06:15 AM
Missing vacuum connection jimbo2807 Tiger Workshop (archive) 1 10-12-2006 06:22 PM
Carbon Canister rabbid Club Cafe' 3 09-12-2006 11:56 AM
