Old 10-02-2005   #1 (permalink)
dat
Have done 5500 k's . Since I had the bike it has sometimes missed top gear. I change from 5th to 6th it clunks into place I let out the clutch and then I can hear the gears grinding, after that I am freewheeling??? Change up again and into 6th.
anyone else with this problem, trumpy dealer told me the gears need to mesh together ???This only happens when I'm going hard. Since May it has only happened about a dozen times. Any suggestions??
Old 10-02-2005   #2 (permalink)
I have noticed that proper shifting on My '05 Sprint is very sensitive to proper chain adjustment. As the chain becomes loose shifting eases deteriorates rapidly.
1100x is offline   Reply With Quote
Old 10-02-2005   #3 (permalink)
ST
ST's Avatar
Dat, try doing clutchless change ups.... gearbox is superb when clutchless. very precise and far smoother.
also agree with the chain adjustment and most importantly decent lube.... build up of chainwax caused a similar shifting problem on my last bike.
ST is offline   Reply With Quote
Old 10-02-2005   #4 (permalink)
dat
Thanks for the advice guys. will try a lube and tension. Will keep you posted on how I go. Dont know if Im game to try a clutches gear shift, it doesnt damage the gears???
Old 10-02-2005   #5 (permalink)
ST
ST's Avatar
no damage as long as you downt downshift !
best done from 3-4th and up wards.... just remeber to quickly shut off the gas as you go....
Same effect as using a Q-shifter but you need to use your feet instead of yer thumb !
Old 10-02-2005   #6 (permalink)
Favorite Bike: 2002 Sprint ST
Instead, try adjusting your shifter a little lower, maybe a 1/4 inch. This will give you a more positive shift throughout the range.
Also, preload your shifter.
I really wouldn't do the clutchless shifts. These aren't like an old crash box Muncie and you may damage the shifting forks.
I know several do it but I also know some that have had troubles.
Personally, Mine was the same way and after adjustment I haven't had a problem in almost 3 years.
Don
Old 10-03-2005   #7 (permalink)
I have the same problem.
Adjusted the clutch and shifter. It happens less frequently but it still happens. DON'T DOWN SHIFT, it can be very scary.
Bo Willyard
Flower Mound, TX
Be Safe!
Achtung! böse Eichhörnchen!
bowillyard is offline   Reply With Quote
Gearbox... blueyzarsoff The Rocket Science Forum 11 12-21-2007 09:34 PM
gearbox deano1050 Sprint Forum 14 06-06-2007 01:55 PM
***** gearbox scouselee Speed Triple Forum 5 10-27-2006 05:00 PM
Gearbox Woes OzBloke Classic, Vintage & Veteran 10 09-26-2006 05:53 AM
Gearbox Daytona Deliberations 0 05-07-2004 06:26 AM
