Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 09-20-2005   #1 (permalink)
I'm trying to hook up a Kisan Signalminder automatic turn signal cancelation and running light option on my Sprint. I notice that the flasher unit is under the right front fairing. How do I remove the fairing panel to access this?
Thanks!
Regards, George
GeorgeT is offline   Reply With Quote
Old 09-20-2005   #2 (permalink)
Take out every screw that you can see attaching the fairing. Then there are two underneath the bike that hold the two lower halve together. Don't forget the ones in the wheel well (behind the front wheel). Next remove the panel that the glove box cover is part of, one black screw and pop the little tail out, you don't have to completely remove this just the back part needs to be lifted up far enough to see the last screw. Now you will see one more screw. The fairing should now be just hanging on a dowel (pin) lift up and your done.
I think this is all, I am doing it from memory.
Bo Willyard
Flower Mound, TX
Be Safe!
Achtung! böse Eichhörnchen!
bowillyard is offline   Reply With Quote
Old 09-20-2005   #3 (permalink)
Oh, yeah Good Luck, it's not hard, you can do it.
[ This message was edited by: bowillyard on 2005-09-20 10:36 ]
Bo Willyard
Flower Mound, TX
Be Safe!
Old 09-20-2005   #4 (permalink)
Okay, thanks for the quick response Bo! I'm going to try it now and I'll let you know how I make out.
Regards, George
Old 09-20-2005   #5 (permalink)
And... if the side panel still appears a little stuck...
the panel is located on a verticle pin/posts eithe side of the tank so you need to remove all the screws and then lift the main panels vertically !
Neil
"Thus bats rally quack" Yer Maun - Joseph.
neil1052 is offline   Reply With Quote
2005-2006 Sprint ST Seat Removal/Installation Thread Alsworld Sprint Forum 27 09-15-2007 09:51 PM
front wheel removal Sprint ST rjj911 Modifications & Workshop Talk 1 08-31-2007 04:16 AM
07 Sprint ST Fairing Removal Dlanod Sprint Forum 6 01-28-2007 12:26 PM
Fairing Protectors (Bobbins i think they're called?) for the 2005-6 Sprint ST. TattooedRedHead Sprint Forum 4 03-03-2006 08:23 AM
Where can I get a Wraith Fairing for my 2005 Speed triple Modifications & Workshop Talk 1 05-09-2005 05:36 PM
