If you replace the top bearing with a #7205 Annular contact bearing you will have a better setup. The top bearing in these bikes are not designed for side loading which is exactly what happens when you adjust the play out of the system. It's a poor design. Annular contact bearings are designed for radial and side loading and the number I gave you is a drop in replacement. With it you stand a much less chance of chipping the races and or balls and can actually load the assembly without damage to the bearing.
There is also a tapered bearing available, but it's about 1/16" to wide. It will also work, it's just a bit wider and they can be had for about $10.00. That is a #33205.
I adjust mine by 'HAND ONLY' when it comes to the actual adjustment I use the socket in my hand and tighten is as much as I can, move the bars back and forth a couple of times,(you did repack the lower bearing with grease, right) and then re-tighten the adjusting nut again with the socket in my hand as tight as I can. Then just be sure it doesn't get tightened more when you tighten the lock nut. I still have the original (poor design) bearing in mine ad this procedure keeps them from being overloaded and damaged. My bike is approaching 20K on the odometer with the original top bearing. If it dies, I'm going to change to the 7205 Annular bearing.
