Trident-Exhausts.comMotorcycle.comAdvanstarMotorcycleShows
Old 09-07-2005   #1 (permalink)
Favorite Bike: 2005 Sprint ST
triumphite's Avatar
So easy in a Honda :-D
Wondering if it was something I could do myself? Does the Sprint use special plugs? I think mine might be fouled.
It takes about 8/10 cranks before it fires up. It's been doing it ever since I bought it. :???:
If you live in the DC area, click this link:www.dcrats.com
triumphite is offline   Reply With Quote
Old 09-07-2005   #2 (permalink)
FWIW my 02 when cold never fires on the first crank; usually takes 8-10 like you say yours does. I've read that from others about their bikes on this forum as well.
Tony
g027605 is offline   Reply With Quote
Old 09-07-2005   #3 (permalink)
Favorite Bike: '03 Sprint ST
They usually get better with a couple of miles on them. My '03 doesn't want to start when I put Premium (93) in the tank.
pushr0d is offline   Reply With Quote
Old 09-07-2005   #4 (permalink)
triumphite's Avatar
I'm going to tryone level down on the gas next tank. See what happens :upthumb:
Old 09-07-2005   #5 (permalink)
Well, FWIW, mine has rarely been cranked more than once to start. And I use premium in her all the time, really cut down on some mild pinging with mid-grade fuel. :wink:
hootieST is offline   Reply With Quote
Old 09-08-2005   #6 (permalink)
FWIW, my RS starts up right away and I use 93 octane. I recently changed the plugs to Iridium. Some noticable difference. Not a hard process, just a little lengthy due to removing tank and airbox.
It's all good...
vanpraag is offline   Reply With Quote
Old 09-08-2005   #7 (permalink)
triumphite's Avatar
Will gas leak out?
Old 09-08-2005   #8 (permalink)
It isn't too difficult to remove the tank, especially if it isn't full.
Remove one bolt and you can lift it up to access the fuel line & pump wires. Word of caution -- place a rag between the front of the tank & the triple clamp to avoid gouging the tank. That is unfortunate experience talking there
If you remove the fuel line at end furthest from the tank, it won't leak. I tried removing it right at the tank first, and had gas running everywhere.
I'm not sure about the plugs, though. Haven't had to do that yet.
[ This message was edited by: bz919 on 2005-09-08 10:45 ]
bz919 is offline   Reply With Quote
Old 09-08-2005   #9 (permalink)
ST
ST's Avatar
the 05 sprint does take a few turns to fire up. just remember not to use any throttle when starting as this wont help.
changing your plugs wont help at all its a normal characteristic of the 05.
powerlet plugs and tank bags yoda Sprint Forum 3 07-16-2007 12:37 PM
How do you change the gas tank? 24gt Speed Triple Forum 5 03-17-2007 11:25 AM
any easy was to change valve shims KidThunder650 Sprint Forum 2 03-05-2006 02:23 PM
spark plugs schmark plugs DaleE Hinckley Classic Triples 6 10-25-2005 10:54 AM
First oil change, gear change still clunky M2MG Speed Triple Forum 3 09-03-2004 12:30 PM
