Sprint Suspension Upgrade Options - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-10-2010, 03:17 PM   #1 (permalink)
Main Motorcycle: 2006 Sprint ST ABS
champ87's Avatar
Extra Motorcycle: 1973 Yamaha RD350
I have just posted in the maintenance and tips section describing rebuild work to the forks on my ’06 Sprint ST. There is plenty of information scattered around the forum but it took a lot of searching before I made my final choices for upgrade. I’ve pulled the key points together in one place and posted here for anyone else who’s looking at suspension upgrade for their Sprint ST. Hopefully it’ll save you much of the searching and reading that I did – although you’ll soon have to search to find this post! This is not a list of everything that is available so, hopefully, others will add more.
First step in the process was to get the stock setup working properly. Last year I replaced the fork oil with fresh Bel-Ray 10W fork oil and made sure it was set to the correct level. Then I adjusted preload to set front and rear sag. I didn’t have any issues with bottoming or topping out so I stuck with my initial settings. I played around with the rear shock rebound adjustment to get a setting that felt right. With my suspension set that way I can find an acceptable setup for my weight (165 lbs = 75kg) but I know there's room for improvement. Money was not an obstacle but there has to be a limit. If I consider the market value of an ’06 Sprint then it doesn’t make sense to me to spend $2,000 on suspension.
Here are the options I considered:
Fork Springs
This is the first step in the upgrade process. Changing the stock progressive springs for straight rate gets a unanimous thumbs up from those who’ve made this swap. At around $110 for a set of springs this is a cost-effective improvement. There a several sources including Race Tech, Eibach, Traxxion Dynamics and Sonic.
For a low cost upgrade changing springs and replacing the fork oil may be enough for some. Ideally damping should be altered to the match new springs and rider preferences. There are various ways to change damping:
Reconfigure Stock Showa Shim Stack
This old thread contains some excellent information about the stock Showa damping. The OP is using his knowledge to work within a budget. Most of us do not have that experience so we’d have to turn to professionals at which point this may not be an attractive option.
Replace Stock Valves
For most of us replacing the stock compression and rebound valves will be easier, quicker and more cost effective. It does require some skill and at least a basic understanding of suspension. Those who don’t feel comfortable doing the work themselves can turn to professionals. Most popular choices for replacement valves are:
  • Race Tech Gold Valves – Race Tech claim that their Gold Valves reduce the unnecessary harshness caused by the restrictive ports of the stock pistons. Race Tech Gold Valves come as a kit of parts that are assembled in place of the original Showa valves. The kits allow the compression and rebound valving to be configured to suit the rider. The stock Showa forks have no external damping adjustment but, if necessary, changes can be made by adjusting the shim stack. The current cost for Race Tech Gold Valves is $180 for compression and $170 for rebound valves.
  • Traxxion Dynamics Axxion Valves - Traxxion makes similar claims about their Compression Valve & Rebound Axxion Valve being superior to the stock damping pistons. According to Traxxion’s website their valves are manufactured by Penske. I don’t have any experience with these but they look good in the website images and Traxxion certainly has a very good reputation. Reading the product details reveals that some Axxion Valve kits include shims to revalve the rebound side of your cartridge. Replacing the rebound valve is a better solution but if it’s possible to revalve the rebound portion the Sprint forks then those on a budget could find a cost saving. Current prices are $150 for compression and $176 for rebound valves.
Replace Cartridges
Traxxion Dynamics AK-20 Axxion Cartridge Kit. This is a very sweet solution – but at a price. The AK-20 Axxion Cartridge Kit is a complete replacement for the stock cartridge. At $1000 the kit is expensive but it does include springs and fork oil so that must be taken into consideration when comparing prices. Looking at the AK-20 cartridges it occurred to me that it wouldn’t be difficult to add external rebound damping adjustment to Sprint forks. That’s certainly something to ask about if you’re considering the AK-20 kit.
USD Fork Conversion
On this forum we have a superb thread covering all aspects of converting of a Sprint to USD fork setup using TLS, Hayabusa or possibly GSXR forks. For those with the ability, resources and motivation going inverted is a great solution. The final result looks sharp and may well cost less than upgrading existing forks – particularly if you can sell your original forks. USD forks usually have external adjustment making fine tuning a bit easier but you still don’t have custom settings so further work may be required to tune the suspension. Depending on model and year of donor bike the original springs may be unsuitable for some riders. On some donor bikes the spring rates are the same as the stock springs in Sprint forks and may not work well for heavier riders. USD forks with custom springs and valving would have to be the ultimate suspension upgrade mod for a Sprint.
Rear Shock
Improvements to the front forks are going to highlight any deficiencies at the rear. Options for the rear shock are:
  • Rebuild Stock Rear Shock. The stock Showa rear shock will provide good results with a few simple mods. Older shocks will benefit from a rebuild with new seals, shaft bushing, oil and nitrogen recharge. Improvements to damping can be achieved by adding a Race Tech Gold Valve and Rebound Separator. Depending on rider weight the stock spring may be up to the task but heavier riders will likely require a new spring with preload spacer. Rebuilding the rear shock is not as straightforward as adding valves or cartridges to the front so most will opt to have the work done by someone else. A full rebuild including spring, preload spacer, Gold Valve and Rebound Separator, seals and nitrogen recharge will cost around $450. A $200 saving can be made if the Gold Valve and Rebound Separator upgrade is not included with further reduction if a new spring is not required.
  • Replacement Shock. For those who prefer to put their money towards a new shock there are several options. Penske and Ohlins appear to be the most popular choices. A Penske Shock with correct spring is $625 with the option to add a remote reservoir for an additional $250. For the Sprint Ohlins specify their TR703 rear shock with a piggy-back reservoir and remote preload adjustment. A TR703 will set you back around $1,100. Shocks with a remote reservoir will need some thought about where the reservoir will be located. The usual locations are very close to the exhaust system – not good.
Other Stuff
When considering suspension upgrades we have to make sure that existing components are in good condition. While upgrading the front suspension it is not necessary to completely dismantle the forks but it makes sense to do that to replace the seals. Bushings should also be replaced unless they are fairly new.
At the rear regular maintenance will ensure that wheel movement is not hampered by excess friction in the linkages. It is easy to ignore drag link and drop link bushings, sleeves and seals but these components should be cleaned, inspected and greased from time to time for the suspension to give its best. Swingarm movement should be checked too.
Cont….
Champ87
It's amazing how fast you can go when you take your time.
champ87 is offline   Reply With Quote
Old 12-10-2010, 03:20 PM   #2 (permalink)
champ87's Avatar
…..contd.
My Setup
After considering all the options for the front I decided that new fork springs were a no-brainer. The springs combined with new oil would render some improvement at a modest cost. To upgrade the damping I selected Race Tech Gold Valves for both compression and rebound.
At the rear I opted for a rebuild of the rear shock with Gold Valve and Rebound Separator. Initially I thought that the money may be better spent on a quality adjustable shock but thanks to Tmod I moved away from that idea. He told me that the stock rear spring was “darn near perfect” for my weight (165lbs) so the stock spring was retained and a 4mm preload spacer added. I didn’t want to spend a stack of money on a new spring that wasn’t necessary and a zillion adjustments that wouldn’t be used once the shock was set.
Notice that I haven’t gone into detail about spring rates, preload and shim stacks. I’d be happy to provide that information but the whole point of the exercise was to tailor my suspension to suit me. My settings will not be relevant for other riders unless they are the same weight, use the bike in the same conditions, have the same preferences and riding style. I consider my riding style to be brisk but not aggressive. I try to maintain a smooth, flowing style by setting up early for corners. That allows me to run my suspension a bit softer than some riders would prefer. I don’t equate hard suspension with hard riding and I don’t get freaked out about the front end diving under braking. Most bikes do that (unless they have anti-dive or weird suspension) so I look for well-controlled weight transfer coming off the brakes onto the throttle.
Verdict
Unfortunately the current spell of cold weather here in Missouri has not encouraged me to venture out to put the new setup through it's paces. I'll report my impressions as soon as I've had a chance to go out and give it some serious grief.
Champ87
Old 12-10-2010, 03:36 PM   #3 (permalink)
Main Motorcycle: 2007 Sprint ST ABS
Stravoxylo's Avatar
This is a nice summary of the options, with helpful links included!
I hope you get some nice "testing" days in the next few weeks, as I would be interested in your evaluation of the new setup.
Guinness is good for you!
Stravoxylo is offline   Reply With Quote
Old 12-10-2010, 05:24 PM   #4 (permalink)
Main Motorcycle: 08 Sprint ST
Other Motorcycle: Yamaha YZ426f
First of all. Nice summation of avaliable options. With some practical, and well put advice, on each.
Originally Posted by champ87 View Post
Replace Cartridges
I can confirm the add on of adjusters is an option from them. They did it too mine. It's more or less the same kit as THIS. They make one fork compression control. The other fork rebound control. I can't recall what they actually cost for the Sprint, but probably not far off what they list there.
After using a remote reservoir Penske for a year, I'd suggest going with the piggy-back reservoir. I've struggled with locating the res on mine where it won't be on the exhaust pipe side, out of the chain run, not pinched by the swingarm, not in the way of the bags, and not in the way of my left heel when riding agressively. I definately haven't been successful on that last one, and now the rubber cladding of the hose has been nicked by something around the chain guard. No leaking, but still damaged.
Steven
World Storehouse of Useless Knowledge
Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity.
SprintST is offline   Reply With Quote
Old 12-10-2010, 06:02 PM   #5 (permalink)
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Thumbs up Nice summary Champ
Good summary Champ, you are right we have a lot of info but much is here there and every where
DaveM
My album click here;
http://www.triumphrat.net/memberalbu...er/2712/sort/3
DaveM is online now   Reply With Quote
Old 12-10-2010, 06:14 PM   #6 (permalink)
Tmod's Avatar
This thread should make it a tad easier for those looking for suspension info and wanting a little advantages and dis-advantages look at things.
Thanks for posting what you found on your search for better suspension.
Tmod
The Best You've Ridden Is The Best You Know
Tmod is offline   Reply With Quote
Old 01-11-2011, 02:45 PM   #7 (permalink)
morvegil's Avatar
This is the thread ive been looking for!
2012 Speed Triple R
2010 Ducati Streetfighter
2008 Triumph Sprint ST (sold)
2008 Harley-Davidson Night Rod (Sold)
morvegil is online now   Reply With Quote
Old 01-11-2011, 04:59 PM   #8 (permalink)
Main Motorcycle: Ducati Multistrada
scott1050's Avatar
Other Motorcycle: 1980 Honda CB750F
for everyones info I had the Traxxion Dynamics AK-20 for the forks and had them rebuild and revalve and spring the shock. Total is $1778.53.
Go out and enjoy a ride
scott1050 is online now   Reply With Quote
Old 01-11-2011, 05:35 PM   #9 (permalink)
Main Motorcycle: 2003 Sprint ST
Other Motorcycle: 2004 Ducati 999S
Extra Motorcycle: 1974 Norton Commando S3
Elka should now be able to supply a shock for 2nd generation Sprints. I had one custom built by CM Motorsports (Tustin, CA) and they provided detailed specifications back to Elka. The 2nd gen Sprints have ample room for a remote reservoir under the seat and their conventional exhaust makes that practical. Also, I highly recommend hydraulic preload with the knob located where you can adjust it while riding. I find that a small change makes a big difference if you are doing it while you can feel the effect of the change.
As for USD fork swaps, the biggest issue is finding donor forks that are long enough to retain the Sprint's stock geometry. Too short a fork will seriously change the bike's handling dynamics. I used '06 ZX-14 forks that are considerably longer than those used on a GSXR, R1, etc. and they still had to be lengthened internally by 10 mm.
The people who talk the most generally have the smallest results. Results speak for themselves. - Matt Mladin
Coroja is offline   Reply With Quote
Old 01-12-2011, 09:09 AM   #10 (permalink)
steves's Avatar
On the subject of a USD fork conversion, that was on my list of possible alterations. The reason I decided not to go this route, is that I really like the seating and bar position on the sprint. Most of the USD conversions I've seen have people going to lower clip-on bars or whatever was stock on the bike, or having to add LSL or similar top plate adapters to go back to a similar bar height. After calculating out total cost, re-valving the forks and new springs was a better option IMO.
I've been very pleased with my current RaceTech setup over what Triumph provided from the factory.
It still unsettles me somewhat that the tiger gets USD forks, but the Sprint doesn't. I think I would have been willing to trade the luggage for better forks from Hinckley... but what do I know
08 Sprint ST ABS
steves is offline   Reply With Quote
front brake upgrade options for '72 T150V? IronYuppy Classic, Vintage & Veteran 10 12-18-2010 07:35 PM
60s tig suspension upgrade? T100SS Classic, Vintage & Veteran 0 09-27-2010 11:15 AM
Suspension Upgrade Options on a 2000 Tiger 900 haroldo_psf Tiger Mods & Bolt-Ons (archive) 21 08-06-2010 07:12 PM
Suspension upgrade larryshep Twins Talk 12 08-11-2005 05:45 PM
05 Fork upgrade options viper3256 Sprint Forum 2 08-08-2005 05:06 PM
