BikeBanditAdvanstarMotorcycleShowsTrident-Exhausts.comMotorcycle.com
ShopTriumph.com
Old 08-28-2005   #1 (permalink)
Greetings,
After a couple of weeks on the Sprint, the only glitch that constantly annoys me is the curious starting procedure. When I first got the bike, I would crank it once for a couple of seconds, and then it would always start on the second crank. Warm or cold. Now, it seems completely inconsistent, sometimes catching on the first crank, sometimes cranking twice, three times, or four times in a parking lot yesterday. Warm or cold makes no difference, either. I commuted to work last week for three days successively, and the starting issue was the only frustration I had. The bike is going in next week for the fuel connector recall, and I'll have them check it out. I have run several tanks of fuel through on my drive home when I bought the bike. The previous owner was the one who taught me the 2 crank start procedure.
Any ideas?
Thanks,
[ This message was edited by: vorpal on 2005-08-28 10:11 ]
vorpal
http://www.atonal.ca/frugalgarage/sprint/sprintsig.jpg
'01 Sprint ST
Sapphire Blue
Givi Monorack with topbox and E-41 side panniers
vorpal is offline   Reply With Quote
Old 08-28-2005   #2 (permalink)
I had a 00St for 5 years Stood outside all that time rain shine snow ice the lot always started first time. Method turn key wait 5 seconds for fuel pump to do its thing hit the start button Crannnnnnk start, the main thing never touch the throttle not even a little let the engine management do it's stuff. Hope my new ST 1050 is as good when I get it, the old one only let me down once on starting and that was after 3.5 years battery was ready for replacement.
russ1610 is offline   Reply With Quote
Old 08-28-2005   #3 (permalink)
JR57's Avatar
My 01RS (made11/00) has allways started after what "sounds like" 3 or 4 spins. Hot / cold, didn't matter. Turn key on, wait a few seconds for fuel press. (you can here mine,Eeeeeeeeee) click starter, wrwrwrwr Brrrrrrr. Like Russ said, don't touch throtle. I've heard a couple of other Triumphs sound the same, thought maybe low geared starter. ?? JR
JR57 is offline   Reply With Quote
Old 08-28-2005   #4 (permalink)
Yup, turn key, fuel pump *eeeeer* dash lights brighten (roughly 4-5 seconds) and then crank. Sometimes catches 1st try, but usually 2nd time (not cranking longer than 5-6 turn-overs). Last couple of days, 3 or 4 cranking sessions. No throttle, clutch in. Not fun. Bike jumps to life immediately, something's not on the level here. I'll let you know what I find when the bike goes in this week.
Regards,
vorpal
'01 Sprint ST
Sapphire Blue
Old 08-29-2005   #5 (permalink)
When was the last time you changed your plugs?
Dan
Black misslie pilot :-)
Aussie_955_ST is offline   Reply With Quote
Old 08-29-2005   #6 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
Mine has always started first crank. Plugs, wrong tune, stale fuel?
davem
Old 08-29-2005   #7 (permalink)
Favorite Bike: '03 Sprint ST
My '03 doesn't start worth a ***** when I put Premium (93) in it.
I usually run Mid-grade, and the bike seems to prefer it.
pushr0d is offline   Reply With Quote
Old 08-29-2005   #8 (permalink)
Favorite Bike: 2002 Sprint ST
Key on, wait for the fuel pressure regulator to quit making it's noise and fully charge the injectors. Do not touch the throttle and hit the button with the clutch in.
Should start every time like mine.
Don
Old 08-29-2005   #9 (permalink)
Favorite Bike: 2002 Triumph Sprint ST
Panthers_Den's Avatar
Other Motorcycle: Future: Blue '08 D675
interesting, i'll have to try that when i get my bike back. i always turned the key and hit the start button immediately and it always had trouble (the few times i had a chance to use it) starting up. I was figuring the battery was going bad since it's 3 1/2 yrs old already. I seem to learn something new everyday about this bike. hehe
'02 Sapphire Blue Sprint ST
My Photo Album
My Archived Photo Album
www.myspace.com/panthers_den
Panthers_Den is offline   Reply With Quote
Old 09-07-2005   #10 (permalink)
Follow up on the hard starting: Looks like my regulator/rectifier on the alternator is shot, and the battery wasn't charging. Explains the harder and harder starting. Now for the bad news: $ 350.00 (Canadian) for the part, some labour to install and *10 days wait* while it is shipped up from the US! No Canadian parts distributor, and the shop service guy tells me Triumph US don't expedite anything! The weather is perfect for the last two days, who knows how long this will last? Grrrrrrrrrrrrr. I want my bike back.
Thanks, I needed to do that.
Also, the alternator is a Nippon/Denso 8 diode unit. I can't believe with all the Japanese bikes out there, nobody can source the regulator/rectifier unit locally and I have to wait for Triumph to supply one. Sigh.
Regards,
vorpal
'01 Sprint ST
Sapphire Blue
Starting Issue taffgmg T3 Sport / Touring Forum 8 04-14-2008 02:05 PM
S3 starting issue limeeee Speed Triple Forum 10 12-21-2007 10:51 PM
(non) starting issue TBSstunta Hinckley Classic Triples 4 07-16-2006 10:39 AM
03 Sprint St, Starting Issue perfectweb Sprint Forum 4 04-30-2005 09:06 PM
Starting issue ToddZimardo Modifications & Workshop Talk 2 07-29-2004 05:06 AM
