ok, 05 ST, new noise.
When in neutral there is a whirling/fan type noise coming from the gearbox (no it is not the radiator fan). If I pull in the clutch lever it dissappears. I can pull the clutch lever in and let it out and each time the noise appears and dissappears.
Im concerned for 2 reasons:
1. the noise is new
2. dont want the bike going into gear on its own
I checked the clutch linkage/lever/cable and it all seem ok. But there in a tiny bit of oil that has come up through the clutch lever seal at the top of the case and trickled down the cover.
Any ideas?
Thanks
Mike
How fast can you slow?
GnuPG ID:BD1D95AD
