BikeBanditMotorcycle.comAdvanstarMotorcycleShows
Old 08-19-2005   #1 (permalink)
apart from the odd sticker or colours, are there any mechanical differences between the 2000 and 2004 model STs? i want a haynes manual for mine but they only list years up to 2000.
keep it pinned guys. or gals. or some of those strange types you see in Brighton
dave usually, or whatever the wife feels like calling me at the time
davsato is offline   Reply With Quote
Old 08-19-2005   #2 (permalink)
Favorite Bike: '03 Sprint ST
Dave,
'99 - '01 are the same (except for colors) and '02 - '04 are the same (ditto). Significant differences in engine configuration occurred with the '02.
Keep an eye out for the Factory manual. They sometimes pop up on eBay.
Steve
pushr0d is online now   Reply With Quote
Old 08-19-2005   #3 (permalink)
Favorite Bike: '02 Sprint
Here's a write-up of the changes from an on-line brochure. The frame and hardware are pretty much unchanged.
The engine changes offer even more of the long-legged performance the Sprint ST is renowned for. The new 120bhp powerplant is identical to the new 955cc three-cylinder engine fitted to the new Speed Triple and Sprint RS. Employing high-pressure die-cast crankcases for both strength and lightness, the DOHC 12-valve liquid-cooled engine's new cylinder head utilizes 1mm larger inlet valves and 1mm smaller exhaust valves, set at a narrower included angle. Both inlet and exhaust ports are redesigned for better gas flow and the new cast pistons run in steel liners. Compression ratio is up from 11.2:1 to 12:1.while crankcase breathing is revised to minimise power loss. The new engine is 2.5kg lighter than before.
A larger airbox feeds the new closed loop fuel injection system which features smaller, lighter injectors, while compact, light plug-top ignition coils provide dependable high-intensity sparks. The closed-loop system features an oxygen sensor that monitors and adjusts the air:fuel ratio at varying engine speeds to optimise engine performance. The fuel injection mapping is tuned for even more mid-range torque making the Sprint ST's punchy three-cylinder performance even easier to use to the full.
As on the Speed Triple engine, the alternator is now located on the left-hand end of the crankshaft and the starter motor drive is located on the right. This layout, reduces noise, especially at idle, as there's now no need for a gear-train to drive the alternator. And a revised claw-type gear-change mechanism gives a much smoother and more positive shift action.
The exhaust system has new headers and balance-pipe to further boost midrange output and for the German and Californian markets a secondary air injection system is fitted to minimise emissions. Cooling and lubrication systems are revised with the coolant radiator featuring a thinner core, increasing efficiency without adding size or weight. The Sprint ST is available in distinctive British Racing Green, cool Sapphire Blue and dashing Tornado Red
PaloAlto is offline   Reply With Quote
Old 08-19-2005   #4 (permalink)
I like the part about the Tornado red being "Dashing" :-D
"Dreaming of falling asleep, again"
my piccys
DragonDan is offline   Reply With Quote
Old 08-20-2005   #5 (permalink)
thanks guys, i wont bother then with the haynes book.
incidently, the green ST(like mine) is called ASTON GREEN officially, i heard triumph couldnt call it BRG because the name is copyrighted and owned by someone else who refuses to let others use it, like bentley or someone. i call it BRG, so up yours whoever you are. :hammer:
Old 08-20-2005   #6 (permalink)
hmm, not sure the Trumpy Aston green is the same colour as BRG.
Cheers, Ern
Motorcycle Sports Touring Club of Victoria, 50th anniversary year, Club website
ST-ern is offline   Reply With Quote
Old 08-20-2005   #7 (permalink)
its not Ern, its metallic and BRG is "greener" if you know what i mean.
Old 08-21-2005   #8 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
Is it the numbers that are different, I'm a bit slow?
davem :-D
Differences across 955/1050 models kludge Sprint Forum 13 07-09-2008 11:02 PM
Sprint differences? clyde Sprint Forum 8 02-12-2008 11:13 PM
Sprint '07 differences ElTigre1 Sprint Forum 5 04-09-2007 05:34 PM
What are the major differences b/t 2000 and 2003 models years? Speed Triple Forum 15 11-19-2004 05:42 PM
96 VS 2000 plus models; MAJOR DIFFERENCES?? Trophy 6 05-06-2004 11:36 PM
