Let's get the obvious DUH questions out of the way :-D
Is your oil level up and proper? Is the viscosity of the oil proper for your local ambient temperature conditions? IS there a temp. problem, or is this happening at a normal operating temperature?
Were me, I'd check that all the above were as they should be, then see the dealer. It is still under warranty. He should check for faults, this might show something amiss. If there is a problem, at least you have started a paper trail and go from there.
There could be many causes for this.
Is your cooling system ok? It could have a bubble in it and needs to be burped. This could cause the engine to run hotter than normal, causing your oil's viscosity to drop a bit.
If you have a TuneBoy this should tell you if there any faults. I don't think I'd arbitrarily set the idle higher without checking everything, cooling or oil related first, as this could mask a problem elsewhere.
Like I said though, I'd take it to a dealer and have them explain this out in case it was a bigger problem like the oil pump or a main bearing clearance issue.
Keep us informed on how it goes please as I don't remember anybody else that has had this problem.
Don
