> I can't say for power and milage however they did make for easier starting especially when cold. According to documentation they are also less prone to fouling and last longer.
That's pretty much their real advantage, IMO.
Anyone who sees a power difference after the change had to be running plugs that were already deteriorated. <u>If</u> Plug A and Plug B both start the combustion process consistently at the moment of sparking, there physically cannot be much difference in the outcome. The geometry of the plug tip is simply not that big a factor in the performance of the combustion chamber as a whole.
But if Plug B begins to foul easier or develops internal leakage currents or is susceptible to other problems, then Plug A is clearly the better one to be running...not because it can give you more performance than Plug B did initially, but because it will still give you that performance long after Plug B can't.
John
