AdvanstarMotorcycleShowsTriumph DetroitBikeBanditCommonwealth MotorcyclesMotorcycle.com Classifieds!
Allstate
Ricor Shocks
Old 08-04-2005   #1 (permalink)
I have just fitted Gen Mar Risers to my Sprint ST, they came with a new front brake hose, which I have also fitted. I was just wondering about the sequence to bleed front brakes. Do I bleed left side first ( furthest from master cylinder) or right side or does it not matter. also is it a similar process to a car ie. open bleed valve squeeze brake lever fully home, hold brake lever in until bleed valve tightened before releasing brake lever. Cheers for any advice given.
Peter.
Pebbles is offline   Reply With Quote
Old 08-05-2005   #2 (permalink)
You have the right sequence. I use a mity-vac to bleed brakes on my bike. It will save you from squeezing the brake lever fifty or so times. I use the Mity-Vac till I clear all the old fluid out. I then squeeze the lever and crack open the bleed screw a few times and all is well.
James
Kngelv is offline   Reply With Quote
Old 08-06-2005   #3 (permalink)
Favourite Bike: 04 Sprint St
Other Motorcycle: Suzuki RGV250 track bike
Extra Motorcycle: Fantic 201
A good tip here to save you bleeding the brakes for ages if you do not have an automatic bleeder device is to bleed the master cylinder first. Squeeze the lever, open the banjo bolt slightly at the master cylinder(Plenty of rags underneath though), close and release as you would the bleed nipples normally - It just takes a couple of pumps but clears air from the master cylinder much more quickly. Then bleed the brakes as normal. Tying or bungeeing the lever back to the bar for a few hours afterwards helps push any remnants of air into the calipers, then a couple more bleeds gets you a nice firm lever.
Swampy is offline   Reply With Quote
Old 08-06-2005   #4 (permalink)
I really like having speed bleeders in the calipers. Still use the MityVac on big jobs but they make a quick touch up easy.
Also, if you get a bit of brake fluid on any the black plastic and it leaves a white spot, you can use acetone to remove it. Just be careful, a little goes a long way.
Universal Laws of MC Forums
1. Just because the engine is on and the wheels are turning doesn't mean you're "riding".
2. The bike you ride and the farkles you buy have no correlation to how good a rider you are.
3. The ignorant can be enlightened, but the stupid just drive on forever.
rodneybrown is offline   Reply With Quote
Old 08-08-2005   #5 (permalink)
Cheers Guys.
I accomplished the task over the weekend, no major problems and the bleeding seemed to go without a hitch, once i replaced all the banjo crush washers for new ones ( didn't get any with the new brake line though) had to buy these as seperate items.
Been out for a spin and the brakes are better than before, with slightly less travel back towards the throttle grip.
Also like the Bar Risers takes a bit more weight off my wrists without affecting the handling.
Cheers peter.
Bleeding brakes itcha Club Cafe' 10 06-28-2007 10:57 PM
Bleeding ABS brakes JTXR Sprint Forum 5 06-24-2007 03:05 AM
bleeding brakes abird4 Sprint Forum 7 05-26-2007 09:48 AM
any tips for bleeding brakes? burgessa23 Triumph SuperSports 6 07-29-2005 03:36 PM
Bleeding the Brakes - I need a How-To PassTheGravy Sprint Forum 2 08-08-2004 12:44 AM
Harley Davidson Suzuki GSXR Ducati Forum Kawasaki Forum
V-Rod Forum GSXR Forum Ducati Monster Vulcan Forums
Harley Forum Suzuki SV Honda 600RR Kawasaki ZX Forum
Buell Forum Yamaha R1 Honda 1000RR Kawasaki ZX-10R
KTM Forum Yamaha R6 Honda Fury Forums Triumph Forum
Victory Forums YZF-R6 Forum Honda Goldwing Triumph 675
Can Am Spyder Aprilia Forum Sportbikes Forum BMW S1000RR Forum
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
