Almost the same experience with the front brake (non ABS). Braking is OK but when left overnight its just more spongy. Or better it needs more lever movement. After squeezing the brake several times, it feels good and I don't have to pull the lever that far.
Mine has 2 steel lines going from the pump to the calipers, from new on. I noticed already after fitting that it was hard to bleed, even with 2 lines straight to the brakes. The original lines are replaced because of risers.
Its funny, because if you pull the lever, air will certainly not be bleeded. So air inside will not be the problem.
May be its something with the pistons in the brake calipers. To free the brake pads from the disk, they move just a little bit by the force of a rubber O-ring. Possible its moves just a bit more when left for a longer period. If the brake lever is in its "resting" position, the brake fluid can flow back to the reservoir. After that you have to pump it up again.
Have already seen about in a thread about bleeding etc.
A solution mentioned in that thread was:
Before parking the bike, pull the lever and hold it in that position by a rubber or so. Brake would stay OK.
BTW in that position, brake fluid cannot flow back to the reservoir.
So, for me its not a problem, but I don't know why the brake behaves like this
[ This message was edited by: triomf-ST on 2005-08-01 02:12 ]
