TOR...2008.... map? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-18-2010, 11:12 PM   #1 (permalink)
Favourite Bike: 2008 Sprint ST 1050
the-ROOSTER-'s Avatar
Other Motorcycle: want -DUCATI 848
Extra Motorcycle: want - BMW1200GSA
TOR...2008.... map?
I s*ck at the search engine apparently.....uggh!!!
I installed a TOR (all by myself! ) tonight on my 2008 Sprint ST.... I think it was actually harder to take all the parts off than the exhaust itself, LOL...
I've searched with no luck, but I'm sure it's on here somewhere ---- What MAP/Download do I want to get at the dealer, for a 2008 with TOR??? hope to swing by the dealer at lunch tommorow..... took her out for a quick spin, and damn - it's sounds pretty nice. Not obnoxius, but a little lower and throaty through the 1000-4000rom range, I like it!!! little more burble and pop on the de-cel for now, but I kind of like that too, ha ha... but I'm sure the proper map will help that a little....
also found once I got the seat off - that the Triumph Gel-seat was somewhat uncomfortable (came with the bike) for a reason.... the seat-tab wasnt slotted, the tab itself was loose and angles downward.... bolted up properly, I think it added about 2 cm or so of height back and isnt angled as "downward" as before - also added a slighty bigger "gap" above exhaust, and felt a little cooler already...... or its all in my head, LOL....
cheers if anyone can give me the map # I need to request.....
the-ROOSTER- is offline   Reply With Quote
Old 03-19-2010, 10:02 AM   #2 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
have a quick rummage here to tell you what tune you should have...
Once you have entered your model, it will list all the tunes and you will need your VIN to be sure (up by the headstock on the throttle side)
http://www.tuneboy.com.au/downloads.html
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 03-19-2010, 12:11 PM   #3 (permalink)
Very cool, thanks!!!! ... what would you consider the TOR though? it's not really an "aftermarket" exhaust, but its not stock either....hmmmm....
Old 03-19-2010, 12:22 PM   #4 (permalink)
Favourite Bike: Suzuki V-Strom DL-650
Tri-oomph!'s Avatar
Other Motorcycle: Sprint ST 1050
Extra Motorcycle: I'll take a dozen!
It stands for Triumph Off-Road exhaust, meaning it's supposed to be for track-only use.
Tri-oomph! is online now   Reply With Quote
Old 03-19-2010, 01:27 PM   #5 (permalink)
LOL, believe it or not I know that, ha ha ... maybe I'm taking "aftermarket" too literally? I consider aftermarket produced or manufactured by someone OTHER than the builder of the bike(product), in this case obviously someone other than TRIUMPH. But it is as you point out "off road"(ie-track) only, so I suppose it would fall into that category...
using those standards, looks like tune #20176, I think
aftermarket
standard/stock midpipe
steel tank
vin# after XXXXX
s'all good!
Old 03-19-2010, 02:26 PM   #6 (permalink)
Tri-oomph!'s Avatar
Well, I guess we then call it "factory" as opposed to aftermarket
Old 03-19-2010, 09:56 PM   #7 (permalink)
Favourite Bike: Custom Merckx Pista
JohnTex's Avatar
I would question the stock midpipe. I just had a TOR installed by the dealer, and it came with a stock LOOKING midpipe. It looks stock from the outside, but is sooo much lighter without any cat bits inside.
They downloaded the tune for me without a charge, although that is probably because I was already paying them for the install.
Good luck!
JohnTex is offline   Reply With Quote
Old 03-19-2010, 10:32 PM   #8 (permalink)
Good luck!
hmmmmm...wonder where I could find that.... I bought the TOR used, on eBay -- no mid included, jsut bolted right up....
Old 03-20-2010, 02:59 PM   #9 (permalink)
Tri-oomph!'s Avatar
I have never heard that the off-road exhaust comes with a new mid-pipe. Maybe the earlier versions 05-06? 07? don't need a different mid-pipe since there is not a cat in them anyhow. Perhaps someone else with a newer Sprint who has also purchased the TOR will confirm this.
Old 03-20-2010, 05:04 PM   #10 (permalink)
oldndumb's Avatar
The TOR for the early 1050 (05-06-07?) did not include a mid pipe. It used the existing mid pipe since the pre-cat was in the header pipe. Some time after that, the pre-cat was moved to the mid pipe, thus the TOR for those models includes a mid pipe sans a pre-cat.
Don't quote me on the exact years because I do not have hard info. But I do know that using the VIN number when ordering a TOR will include/not include the mid pipe accordingly.
Oldndumb
Caveat lector
What makes the 2008 thrux a 2008? CaptainCafe' Club Cafe' 6 05-30-2008 04:03 PM
2008 Dragon Raid May 8-11 2008 triumph_955_st Rides & Events 6 04-13-2008 09:15 PM
2008 and pre-2008 gas tanks PhxTrump Twins Talk 9 03-20-2008 02:20 AM
Changes to RAT 2008 postnote General RAT Discussion Forum 1 12-25-2007 01:51 PM
Why there should be a new s3 for 2008 sergio2005 Speed Triple Forum 22 09-02-2007 02:08 PM
