Horns - Troubleshooting The "Click" Only With No Horn Blast
I installed dual Fiamm Horns a few months ago using a relay and everything worked perfectly.
Last weekend I was dressing out wiring(with braided sleeving) on the bike and also installed an Eastern Beaver Fuse Block... now the horns are not working and all I'm getting is the dreaded "click" at the horn relay. Funny thing is after I had wired the Eastern Beaver Fuse Block I tested the horns and no problem.
Since I had problems with the original Fiamm horn relay I went to Checker Auto Parts and bought a new relay hoping that would be an easy fix. No such luck... just a click at the relay when the horn button is pressed and nothing at the horns.
Using my Multi-Tester I confirmed the wires to the horns are continuous.
Because the horn relay is clicking when the horn button is pushed it tells me that the relay is powered and working correctly.
How can I troubleshoot the horns?
Here's a thumbnail of one of the horns:
The horn is grounded when mounted and power is supplied from the relay. How does one property test the power coming into the horns from the relay?
Here's a relay wiring diagram that could be useful as a reference(ignore the reference to the fuse block since the relays function the same):
All help is appreciated.
TR H-Grips, Aero Screen, Axel Covers, Tank Protector, Pro-Oiler, Radiator & Oil Grills, PB Hugger & Fend Extend, Throttlemeister, R&G Crash Bungs & Tail Tidy, Bestem TBox, Fiamms, EB Fuse Block, HIDs, Driving Lights, Brake Modulator, Halo Lighting.
