More headlight advice needed!
This might have been already answered, there's just a lot to look at. I have a "new" out of the crate 2007 Sprint ST ABS. I love it, but the headlights are horrible. First I adjusted the lows up a bit and the cut-off was flashing drivers in their rear view mirrors and I had a couple of cars pull over due to the red/blue strobing that is happening, which I couldn't believe until it happened to me. I went to the dealer yesterday, he adjusted them back down and out a bit. It's a little better as far as flashing the cars, the cutoff is closer to the middle of the trunk of most cars. But, there's still the red/blue at times that once again, caused a couple of cars to pull over for me, last night. I'm for sure going to put, most likely PIAA aux. lights on the fork to help with the inside of the corners, while on back-roads, but wonder if maybe a different bulb (besides HID?) will alleviate the red/blue issue. I talked to Triumph in Atlanta I think it was and was told that the headlights passed and met all DOT requirements. I find that hard to believe. I'd appreciate any advise. Thank you!! I really to love this thing, beautiful Tornado Red, but those headlights!!!!!!!!!!!! Horrible. Thanks again.
