Motorcycle.com
Old 07-08-2005   #1 (permalink)
I searched through and found what I already figured but can find nothing on whether or not I need to remove calipers or if I can just remove the axle and have the wheel fall out without having to remove the calipers. Anybody done this before that can tell me? Also can this be done while the bike is on the centerstand or do I absolutly have to putit up on a motorcycle jack? I could always weigh down the backend so the bike wouldn't seesaw towards the front. May not be the safest method but will that work?
Find something that most people cannot do and do it better and faster than those who can.
DahktahJay is offline   Reply With Quote
Old 07-08-2005   #2 (permalink)
Yes, you must pull the calipers. If you’re working in a garage or under an overhang you can use a tie down strap around the steering head and over a rafter to keep the bike rocked back on the center stand.
Jerry is offline   Reply With Quote
Old 07-08-2005   #3 (permalink)
bluedogok
The calipers stick into the profile of the rim, at a bare minimum you would have to remove one, better to do both because of trying to fit the wheel back on without damaging the speedometer drive pickup is easier with both out of the way.
I had the bike on the centerstand and had my wife hold the back down (I had the rear off at the time) while I pulled the wheel out, then I sat the forks on a milk crate while I ran to Cycle Gear to have the tires changed. I also put the calipers back on with 1 bolt each to relieve the strain on the brake lines while I was gone.
Not the best way of doing it, but it will work until I buy or build some proper stands.
Old 07-10-2005   #4 (permalink)
I ended up just spending the extra $40 for the cycle shop to do the tire "on bike" as they call it. That way if something goes wrong I can point the finger at them. Everything so good so far. I also was able to transport the tire on the bike. I put it on like a life preserver and just rode on down. I got a few double takes on the way there and had another biker pull up next to me at the red light and say "Hey check it out its the Michelin Man!! (sp?)"
Old 07-10-2005   #5 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
I have a good friend who used to race and many years ago rode from Melbourne to Adelaide with two sets of racing slicks on himself as you did.
He really looked like the Michelin man. I think he was planning on rolling down the road if he crashed!
DaveM
Old 07-10-2005   #6 (permalink)
Favorite Bike: 2006 Bonneville
OldSwede's Avatar
Other Motorcycle: 1953 BSA A7
Be careful with that plastic speedometer sensor. It felt fragile
when i put the wheel back.
Whatever you are, be a good one. Abraham Lincoln
OldSwede is offline   Reply With Quote
Old 07-10-2005   #7 (permalink)
Hi Jay,
Actually the front wheel is easy to take off.
For the sake of others this is the processs I followed.
1) loosen the two pinch bolts on the left fork leg
2) get a bolt (1/2 -13 if I remmeber, but don't hold me to that) that fits snuggly into the axle end then gettwo nuts and lock them on the bolt, use wrench to on the nuts to loosen the xale.
3) remove the brake calipers (both of them).
4) finish pulling the axle out
5) wiggle the wheel unitl it is free from the speedo drive or until the spacer on the left falls out.
6) pull the wheel to the left and slowly slide it out.
That's it.
Axle torque on reinstall wa 60 ft lb and pinch bolts It hink 15 or 20. WARNING DO NOT OVER TIGHTEN THE PINCH BOLTS!!!!!!!! IF you do that you will damage the left fork leg.
Preachp
Cruisin\' the byways of life for Christ
preachp is offline   Reply With Quote
Front Wheel Removal?? Ninjaboy Triumph SuperSports 5 07-08-2007 02:57 PM
front wheel removal xlr8r Triumph SuperSports 19 04-21-2006 06:26 PM
Front wheel removal !!! ??? MonkeyHanger Speed Triple Forum 8 03-29-2006 03:47 PM
Front Wheel Removal perfectweb Sprint Forum 7 09-11-2005 10:28 PM
Front wheel removal. Saigon5 Sprint Forum 15 03-26-2005 04:31 AM
