5 minute DIY Sprint ST fairing fix for 05'+ - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-24-2009, 02:49 PM   #1 (permalink)
Favourite Bike: Sprint ST 2005
SprintST_Yes's Avatar
Hey Fellas,
For those of you that have broken-off the lower front fairing tabs, here a good easy fix. I'm referring to the fairing tabs that mate with the oil cooler bracket. So, here is a simple 5 minute DIY fairing fix. Pics attached and Linked here:
Also, once installed, it makes it much easier to install/de-install the bodywork IMO and if done right can be hidden behind the V-shaped cowl.[I]
1.) Grab some Galvanized Strapping Tape (aka: Plumbing Tape)
2.) Drill a couple holes in the smaller holes(seemed like perfect distance)
3.) Cut-off the ends at the dotted-lines with metal shears
4.) Bend as shown
5.) Mount the bolts carefully and the tapes bend will somewhat self-adjust to the right angle.
6.) Remove the bolts and put the lower V-shaped cowling back on (not shown)
7.) (Optional) Paint is optional since the galvanized coating was scratched where the tools hit the tape.
Voila!...Tough as nails.
Disclaimer: Try this at your own risk of course.
SprintST_Yes is offline   Reply With Quote
Old 11-24-2009, 02:59 PM   #2 (permalink)
Due to the attachment fiasco at the moment, I've re-linked the pic to my Flicker site, please re-fresh if you just visited in the last few minutes. Or just go here:
http://farm3.static.flickr.com/2785/...6bcd9562_b.jpg
//YES!
Old 11-24-2009, 03:34 PM   #3 (permalink)
oldndumb's Avatar
Just how does someone go about breaking those clips?
Oldndumb
Caveat lector
Old 11-24-2009, 03:42 PM   #4 (permalink)
Favourite Bike: 2004 Sprint ST
Other Motorcycle: Aprilia Tuono
Extra Motorcycle: Yamaha FZ1
I dunno.
But about five of mine at various points are broken--where the front fairing joins the side pieces on top and along the sides on the forward edges.
They were broken when I got the bike, I think, and I reckon it's vibe related.
--Paul
Berto is offline   Reply With Quote
Old 11-24-2009, 05:03 PM   #5 (permalink)
oldndumb's Avatar
I seriously doubt it is vibration induced. There must be another cause.
Oldndumb
Caveat lector
Old 11-24-2009, 05:03 PM   #6 (permalink)
Pretty easy if you're a bit careless, those lower tabs aren't really that strong. As the story goes, I was in a rush and backing the bike down a ramp off a (monster)truck with a steep angle to the ground and the "second ramp" (used to lessen the angle) was just slightly too far back and then the ramp-hook that grabs the tailgate just snagged the fairings and she went "crack". Yikes!
It's just like stubbing your toe on the coffee table. I lost one of the rear mounts on another occasion, but those aren't so important in keeping the fairing chatter to a minimum like these are. As you can see, my baby's has had some USE you could say, if you didn't notice from the pics. Oopsy! Anyhow, good as GOLD now.
Old 11-25-2009, 12:20 PM   #7 (permalink)
Favourite Bike: Vincent Black Shadow
scritch's Avatar
Extra Motorcycle: Montesa in the shed
I did a recent replacement of a broken tab on my '02 main body fairing, where it attaches to the black fairing in front of the radiator. Made a replacement tab out of Sch 40 ABS pipe using heat gun to flatten, then glued on with black ABS cement. It's been steady rain here in Seattle for weeks, so I haven't had a chance to see how it holds up under long rides yet, but I bet it works.
scritch is offline   Reply With Quote
Old 11-25-2009, 02:01 PM   #8 (permalink)
oldndumb's Avatar
I have always advocated ABS cement for ABS plastic fairings. Seems like a no brainer.
I have also done the pipe cutting and fattening trick. Works good and lasts a long time.
Oldndumb
Caveat lector
Sprint fairing aragorn Sprint Forum 12 04-07-2009 06:44 PM
Sprint ST R/H Fairing RonnieD155 Sprint Forum 0 12-05-2008 05:36 PM
07 Sprint: buzzy fairing tmarsh Sprint Forum 4 05-08-2007 12:45 PM
900 sprint fairing on a Trophy??? Suncoast Trophy 4 11-22-2005 05:52 PM
