Sprint RS clutch cable - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Motorcycle.comSportbikeTrackGearOntario TourismMotorcycle.com Classifieds!Honda Powersports
Old 11-20-2009, 04:51 PM   #1 (permalink)
Favourite Bike: 2000 Sprint RS
AZSprintOwner's Avatar
I apologize for another clutch cable thread. I got some good info from searching, but still have a question.
The parts reference shows you can use this Yamaha cable for a 2000 Sprint ST:
2000 ST - Yamaha part # 1UY3500-3102
Will that work on my 2000 RS with 1" risers? I found my clutch cable very frayed where it enters the clutch lever (you can't see it unless the clutch is pulled all the way in).
Thanks!
Matt
AZSprintOwner is offline   Reply With Quote
Old 11-20-2009, 05:11 PM   #2 (permalink)
oldndumb's Avatar
Can't help you there because while most raise their bars, I lower mine.
But you pose a good question in consideration of the riser height.
Oldndumb
Caveat lector
Old 11-20-2009, 05:11 PM   #3 (permalink)
Immoderate Moderator
Favourite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident in NYC
If you pulled it out of the parts reference, it works. I ordered one from my local Yamaha dealer some time back, and it was a vast improvement over my slightly frayed stock cable. I suspect that part of the reason for the improvement is that the Yamaha part does not have the 90º bend that the Triumph cable has.
As far as ease of installation, it's dead easy. Leave the old cable on, run the new cable along it, detach old and attach new at one end, do same at other end, pull out old cable, adjust new for ~1/8" play at lever.
(Also, double check that moving the bars from lock to lock doesn't activate the clutch, as PO's have been known to misroute cables from time to time. If the cable has been misrouted, the correct route is the one with the least bends and widest arcs possible.)
Cheers,
-Kit
Old 11-20-2009, 05:55 PM   #4 (permalink)
After some more reading, I think the one I want is this one:
1UY-26335-00-00
I'm just going to take it off and go to the Yamaha dealer. He said he'd help me. I dont' want to wait over a week for the Triumph dealer to order it...
Old 11-21-2009, 05:34 AM   #5 (permalink)
Ok, got the Yamaha 1UY-26335-00.
Didn't think I'd be able to get it on at first, as it's about 3 inches shorter than the stock Triumph cable and the reach at the lever end is a tad shorter, but I routed it different and managed to get the barrel ends into their slots. Then got it adjusted correctly, and it still has room for future adjustments. The Yamaha cable even has a rubber boot at the clutch end.
Works great!
Old 01-04-2010, 05:57 PM   #6 (permalink)
Favourite Bike: 01 Sprint ST Sapphire Blu
Dive2277's Avatar
Thumbs up Great post!!!
Thanks for the great post!!! It got me back on the road the next day instead of having to wait almost two weeks to get the part from Triumph because of the New Year’s holiday.
Plus I saved $20 going with Yamaha part # 1UY-26335-00-00 for my 2002 Sprint RS and it seems to be better constructed than the OEM part.
Ride Safe and God Bless,
Stuart
My Precious Black Pearl, Arrrrrr.. (Read w/ Pirate voice) :)
Dive2277 is offline   Reply With Quote
Yam clutch cable for the sprint jefftarlton Sprint Forum 3 01-31-2010 12:26 PM
Sprint ST Clutch Cable NCSprint Sprint Forum 2 11-03-2009 01:55 PM
Yam clutch cable for 955 sprint jefftarlton Maintenance & Workshop Talk 4 02-24-2009 11:58 PM
clutch cable installation on 00 sprint st magnus Sprint Forum 3 04-24-2006 06:36 PM
Clutch cable on Sprint pre-2005 ST/RS? Blissed Sprint Forum 4 04-21-2006 04:44 PM
