Hook the positive wires to the positive output terminal of the regulator, unfused like Triumph did and Shindengen suggests.
Hook the negative wires to the negative regulator output terminals.
Or:
Cap them off and run the negative R/R lead directly to the battery.
Why would you want a 30 Amp fuse in series with a 35 Amp alternator? The RMS currents are higher still, due to the way the regulator works.
A larger fuse would just pose a greater ignition hazard, and I don't mean spark plugs.
The OEM or Shindengen connection solves all of this.
Someone should drop their Sawzall and pick up a calculator for a few minutes.
Documentation, dedication and support are great.
Now make it safe and reliable.
Originally Posted by crlarsen17
I guess I snoozed, so I went ahead and got the kit from roadstercycle.com. Jack mailed it out today. I should have it on Monday. I'm removing all the old stuff and getting ready for the new per DEcosse's writeup. I got a question that I couldn't find an answer to in the writeup. Since you run a positive and a negative from the new regulator straight to the battery, what do you do with the two positive and two negative wires that you cut from the old regulator? Do you just cap them off and forget about them?
