Non std front sprocket. Why? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-18-2009, 11:28 AM   #1 (permalink)
Favourite Bike: ST1050
Eyore's Avatar
Other Motorcycle: Cagiva Navigator
Extra Motorcycle: Gone.
Playing with the new ST 1050 and sussing out everything I had the fairing sides off etc. Came across a funny thing which ties in wuth the optimistically reading speedo. My front sprocket is an 18T rather than the standard 19T also the 18T thats fitted is a plain non cush type.
Wonder why someone dropped the gearing by 1 tooth. Anyone got any thoughts, and should I revert to std set up?
Eyore is offline   Reply With Quote
Old 11-18-2009, 11:43 AM   #2 (permalink)
Favourite Bike: Sprint 06
NotSoFast's Avatar
Many threads on the gearing of the Sprint Eyore. Do a search and you'll find plenty. The reason most people, including me, change the gearing is the stock gearing is too high and changing to an 18 is easy and makes the gearing "just right". YMMV.
No matter where you go, there you are
NotSoFast is online now   Reply With Quote
Old 11-18-2009, 11:53 AM   #3 (permalink)
Favourite Bike: 2005 Sprint ST
3banger's Avatar
Other Motorcycle: KTM MXC 200
"plain non cush type"
It's not really a cush drive per say, it’s just a bit of rubber glued to sprocket to cut down on chain noise. When I replaced my front and rear sprockets while replacing the chain I bought an aftermarket 19toother with no rubber and can't tell any difference in sound. I stuck with the 19t because for a tight twisty (15 to 20mph posted corners) second gear is the perfect ratio and I didn't want to change this.
I leave it for now see how you like it.
3banger is offline   Reply With Quote
Old 11-18-2009, 12:34 PM   #4 (permalink)
Favourite Bike: 05 Sprint
mglemans86's Avatar
Other Motorcycle: 72 Norton Commando
Extra Motorcycle: 86 MG Lemans
Check the rear sprocket also. I just went from 19/42 to 18/43 and what a difference in get up and go.
"Suppose you were an idiot and suppose you were a member of Congress. But I repeat myself."
-Mark Twain
mglemans86 is offline   Reply With Quote
Old 11-18-2009, 12:49 PM   #5 (permalink)
Eyore's Avatar
Thanks for the advice and info. Not having experienced the standard set up I have nothing to compare it to,however it felt fine to me and my only real complaint is the effect it seems to have on the speedo.
Old 11-18-2009, 12:57 PM   #6 (permalink)
Favourite Bike: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
Eyore, the stock bike speedo is 10% high, while the odometer is right on.
The Triumphs are all like that, for some reason.
pushr0d is offline   Reply With Quote
Old 11-18-2009, 01:50 PM   #7 (permalink)
Favourite Bike: 08 Pacific Blue Sprint ST
caddydaddy's Avatar
I have a Speedohealer since I run an 18T front sprocket, so now my speedometer is DOBA with my GPS, but my odometer reads low.
2008 Sprint ST 1050 ABS - Pacific Blue
TOR muffler and tune, 18T front sprocket, Triumph flip-up Aero screen, K&N air filter, Powerbronze Hugger and RAM mounted GPS!
caddydaddy is online now   Reply With Quote
Old 11-19-2009, 09:20 AM   #8 (permalink)
Favourite Bike: 2009 Sprint ST
Most bikes are like that. Can you imagine the furore if a speedo read 10% low ? Well, officer.............
Cars are just the same. Every time I've been caught speeding the reading was lower than I expected
Kintaro is offline   Reply With Quote
Old 11-19-2009, 10:19 AM   #9 (permalink)
Favourite Bike: Triumph 06 sprint st
speedy175's Avatar
1 tooth on the front= 2 up on the rear. I went to a 18 front and went from 42 to 43 on the rear and she pulled like a freight train. Now I left the 43 on the rear and put the 19 back on the front to see how that is.
speedy175 is offline   Reply With Quote
Old 11-20-2009, 12:25 AM   #10 (permalink)
Favourite Bike: 2006 Sprint ST ABS
OP= "Non std front sprocket. Why?"
Glad your front sprocket is disease free.
If its red, itches, burns or has crystals on it, go see your doctor ASAP.
--MMI
MeMyself&I is offline   Reply With Quote
Front Sprocket Jhtjon Twins Technical Talk 16 05-04-2008 11:25 PM
Front Sprocket eternity Twins Technical Talk 3 10-25-2007 07:57 AM
nut for the front sprocket... PrezTT Triumph SuperSports 2 07-18-2007 08:59 AM
Front Sprocket Bushwhacker Hinckley Classic Triples 3 09-15-2005 03:31 PM
18T Front Sprocket Devo Sprint Forum 5 03-22-2005 07:53 PM
