Fuel leak - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-16-2009, 01:55 AM   #1 (permalink)
Favourite Bike: Sprint ST
AAsprint's Avatar
Other Motorcycle: 05 Speedmaster
Extra Motorcycle: 71 Honda sl125
Fuel leak
2000 Triumph sprint st 24k. I have yet another issue. I parked the bike in the garage tonight and noticed a strong gas smell after i went into the house. Walked back in to see a small puddle on the left side of the bike.
I recently took it in to the dealer for a fuel regulator recall. Its been a week and Im thinking it may not be installed properly.
The gas is leaking from the left side off of the frame near the shift lever.
Also when I open the fuel tank I get that whoosh sound every time.
It was doing that before I took it to the dealer. But yet it stopped for the week that they put the regulator or whatever was recalled on it.
So far Ive taken off the plastics to see where its coming from but I cant seem to locate the leak thus far.
AAsprint is offline   Reply With Quote
Old 11-16-2009, 06:22 AM   #2 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Check your quick disconnect fuel connectors first.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 11-16-2009, 05:23 PM   #3 (permalink)
Favourite Bike: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
AASprint,
If you do have a leak from the fuel fittings, do a search for 'fuel fitting'. There are several threads on the subject.
It is a very common problem.
pushr0d is offline   Reply With Quote
Old 11-16-2009, 09:55 PM   #4 (permalink)
AAsprint's Avatar
Well I checked the fuel fittings and they seem to be fine. It has not leaked again but Im sure the problem will arise once more when I at least expect it. Also since it is obviously intermittent Im going to assume that the fittings are the culprit.
Thanks all
Fuel leak and fuel valve confusion screene T3 Sport / Touring Forum 28 01-25-2009 12:03 PM
Fuel leak mglemans86 Sprint Forum 3 10-04-2007 07:24 PM
fuel leak.... help! prez1374 Triumph SuperSports 9 04-13-2006 11:22 AM
Fuel Fitting O-Ring's / Fuel Leak BooneDog Speed Triple Forum 0 01-02-2006 07:34 AM
Fuel leak on RS Unsane Sprint Forum 6 07-06-2005 01:52 PM
