Electrical Issue - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comHonda PowersportsMotorcycle.com Classifieds!
Old 11-14-2009, 11:30 PM   #1 (permalink)
Favourite Bike: Sprint ST
AAsprint's Avatar
Other Motorcycle: 05 Speedmaster
Extra Motorcycle: 71 Honda sl125
Electrical Issue
My 2000 Sprint St has been acting up lately.It has 24k miles,and is stock except for the carbon fiber exhaust. But I will go to turn the key hit the start button and something clicks, then I loose all power even the clock resets. When that occurs all I do is shake the handlebars for a few seconds and all of the sudden I have power again.
Another strange issue is the fact that when it finally is able to turn over it wont keep an idle... I have to give it a bit of throttle no matter if it is hot or cold out. But once I rev it for a second or two It idles and runs normal. Could this be caused by the spark plugs needing to be replaced?
NOTE: Both of these issues started at the same time.
The bike was dropped by a previous owner.. But I have been riding it for the past few months without any issues. Well the little light above the headlights will flicker on and off from time to time.
If anyone has had a similar issue please share. Thanks
AAsprint is offline   Reply With Quote
Old 11-14-2009, 11:50 PM   #2 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Sounds like a loose battery terminal. Unbolt them, clean them and reassemble then try again. Either that or wiggle the kill switch and see if you have some sort of short there.
Calliway is offline   Reply With Quote
Old 11-15-2009, 04:49 AM   #3 (permalink)
Favourite Bike: 1999 T'Bird Sport
lovecuba's Avatar
Other Motorcycle: 2001 Sprint ST
Extra Motorcycle: 1977 T140
Electrical Terminals
Pull the seat and tank. Disconnect every spade terminal in sight (one at a time), clean off all the old grease smeared on the terminals at the factory 9 years ago. Clean up and re-coat with new grease and re- assemble. Pay particular attention to all the earthing points (battery to starter motor via solenoid), clean up with wet and dry paper and coat with new grease.
The factory 'fitted' grease will break down over time and can actually cause short circuts or interrupt current flow across the terminal connectors.
lovecuba is offline   Reply With Quote
Old 11-15-2009, 04:56 AM   #4 (permalink)
Favourite Bike: Sprint ST 1050
soulreaver1's Avatar
Try to measure battery voltage, while engine is starting. If it's less than 12V, means that your battery is out, or starter have a short-circuit.
because Triumph is better...
soulreaver1 is offline   Reply With Quote
Old 11-16-2009, 01:41 AM   #5 (permalink)
AAsprint's Avatar
Thanks guys That issue is now taken care of as another arrives.
Electrical issue maxcyber Twins Technical Talk 1 05-04-2009 07:27 AM
HELP! '96 electrical issue xxfullsailxx Tiger Chat 5 11-14-2008 08:17 PM
electrical issue? doddsy Classic, Vintage & Veteran 4 11-11-2008 09:59 AM
electrical issue... sbpark Twins Technical Talk 1 04-13-2008 11:43 PM
electrical issue - HELP! RoadVenture The Rocket Science Forum 3 11-27-2007 10:50 AM
