Help with connections - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismHonda Powersports Motorcycle.com
Old 11-13-2009, 05:56 PM   #1 (permalink)
Favourite Bike: 06' Sprint St
quakeman3's Avatar
Other Motorcycle: 77' Rd400
Hi, I just installed a used engine in my 06' Sprint st and need some help with the final connections.
I have tried to figure these out,but need help. I had a dealer remove the engine, that's why I don't know exactly where they go. Thx
quakeman3 is offline   Reply With Quote
Old 11-13-2009, 07:44 PM   #2 (permalink)
Favourite Bike: Sprint ST 1050
We could make this into a Quiz ! I'll have first go then ..
Picture 1 is of the petrol tank breather pipe, thats the rollover valve in line to prevent syphoning if the Bike goes over.
Picture 2 Looks like the pipe that goes on the MAP sensor, the MAP sensor is bolted onto the air filter box left hand side, at the top, and the pipe is routed up the side of the air filter box to it.
Picture 3 looks like the fuel pump connector, plugs into the underside of the tank.
Picture 4 - don't recognise that, sorry ! There is an odd connector on mine that goes nowhere, but not sure if that's it..
Don't take my word for it, wait for others for confirmation
Pcdabbler is offline   Reply With Quote
Old 11-13-2009, 07:49 PM   #3 (permalink)
oldndumb's Avatar
Fuel vent hose. Connects to tank at right, forward nipple. As in the pic, the left side connects to the tank.
Pic two, TB vac signal hose to the MAP sensor mounted on top of the air box.
Three is the fuel pump conn.
I'm striking out on the last one. More info such as location and/or wire colors would help if someone does not recognize it.
BTW, what procedure did you us to install and torque the motor mounts?
Oldndumb
Caveat lector
oldndumb is online now   Reply With Quote
Old 11-13-2009, 08:46 PM   #4 (permalink)
quakeman3's Avatar
omg...Thankyou guys so much.I think I have it now.I hope to have it running tomorrow.As for how I installed the motor? I went thru the Triumph service manual and did exactly as instructed.
seat connections jjimmydutch Twins Talk 3 12-24-2008 04:04 PM
HELP Battery Connections EPThomas04 Twins Technical Talk 1 04-17-2008 11:18 PM
Your Rat connections?? denman13 Sprint Forum 11 11-25-2007 10:33 AM
Check them connections! CYNCRZR Club Cafe' 0 02-12-2006 07:25 PM
connections... LCB Triumph SuperSports 1 02-10-2006 01:35 PM
