Front Wheel Removal - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-13-2005, 07:33 PM   #1 (permalink)
Ok, so to remove the front wheel I undo the pinch bolts on the left hand fork leg. Then unscrew the axle and withdraw to the left? How do I undo the axle, there is a hexagonal hole for which I assume a special tool is required (large Allen key?).
Apart from a Triumph dealer is there a workaround for this, like a standard tool that can be purchased or a bodge of some description?
Many thanks
Paul T
[ This message was edited by: perfectweb on 2005-06-13 17:33 ]
perfectweb is offline   Reply With Quote
Old 06-14-2005, 01:24 AM   #2 (permalink)
Favourite Bike: 08 Sprint ST
Other Motorcycle: Yamaha YZ426f
It's not a special tool, well it's kinda special, it's a great big allen wrench. 17mm, or 19mm if I recall correctly. I'm at work so I don't have the tools infront of me. A quick 'bodge' I use to tighten it back down is, find a 1/2" bolt, put 2 large nuts on it back to back, with a lock washer between them.(or weld them in place, which would be better) Then place one end of the bodge in the allen and turn the rest with a regular socket to tighten, and a wrench on the inboard nut to loosen(this way your don't undo the nut instead of the axle). I got lucky and found a large enough allen wrench at True Value, I use it to knock the axle loose. None of the McParts places I went, or Sears, had a big enough allen wrench on hand to buy right then.
[ This message was edited by: SprintST on 2005-06-13 23:33 ]
Steven
World Storehouse of Useless Knowledge
Motorcycling is not, of itself, inherently dangerous. It is, however, extremely unforgiving of inattention, ignorance, incompetence, or stupidity.
SprintST is offline   Reply With Quote
Old 06-14-2005, 05:51 AM   #3 (permalink)
An easy way is to use a 5/8 spark plug socket. Flip it around and put an extension on a ratchet and put it in the socket backwards. The bottom of the socket is a perfect fit. I read that somewhere on the board a few months ago. It worked perfectly when I changed out tires last month.
James
Kngelv is offline   Reply With Quote
Old 06-14-2005, 08:26 AM   #4 (permalink)
Just done mine using the standard toolkit that came with the bike. Just use the plug wrench inside the hexaganol hole, and the large allen key that's also in the kit in the other end of the plug wrench to provide leverage. Works a treat!
Make sure that you don't over tighten the pinch bolts when you replace them, or you could distort the fork tube.
Nigel.
fatboy686 is offline   Reply With Quote
Old 06-14-2005, 08:34 AM   #5 (permalink)
It's a 19mm hex, got one at ACE hardware for something like $9. I've also used the socket flipped and nuts on bolt methods but there's nothing like the right tool for the job :wink:
Eric, CSBA #477 CO. chapter
MRA#633
www.cocsba.com
www.csbracing.com
www.christiansportbike.com
Hell is Hot and Eternity is a long time!
BigE is offline   Reply With Quote
Old 06-14-2005, 06:23 PM   #6 (permalink)
bluedogok
I guess i have a set of 99 forks on my 2000, I have to use a 22mm socket on my axle and all i have ever read is about the 19mm hex for the 2000. But then the build date for mine is July of 99.
Old 06-14-2005, 08:16 PM   #7 (permalink)
Great stuff guys
First port of call, large Allen Key, if unavailable then I'll try the spark plug trick. How difficult can it be.....................?!!
Old 09-11-2005, 11:28 PM   #8 (permalink)
I'm sorry, I have to correct myself here. I just checked and it's a 3/4 inch bolt. Sorry.
Steven
Front Wheel Removal?? Ninjaboy Triumph SuperSports 5 07-08-2007 03:57 PM
front wheel removal xlr8r Triumph SuperSports 19 04-21-2006 07:26 PM
Front wheel removal !!! ??? MonkeyHanger Speed Triple Forum 8 03-29-2006 04:47 PM
Front Wheel Removal DahktahJay Sprint Forum 6 07-10-2005 09:05 AM
Front wheel removal. Saigon5 Sprint Forum 15 03-26-2005 05:31 AM
