sprint st 1050 flat battery/ heated grip gripe?! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-27-2009, 04:02 PM   #1 (permalink)
jimmer72's Avatar
Other Motorcycle: 06 Triumph Sprint st 1050
Hi,
just been out to my sprint and it appears the battery is flat as a pancake - just a couple of questions: battery is 3 years old, but bike up until recently was used rarely - could the battery be knackered and how could i tell? i have heated grips - factory fitted left on last night, i assumed the ignition also cut the power to these -is that the case? and lastly is there a light on the factory heated grip switch?
cheers
jimmer72 is offline   Reply With Quote
Old 07-27-2009, 08:33 PM   #2 (permalink)
CLB
Favourite Bike: '06/'07 Frankensprint
Other Motorcycle: Cannondale Tandem
Extra Motorcycle: Cannondale R1000
1) battery is 3 years old, but bike up until recently was used rarely - could the battery be knackered and how could i tell?
The battery could easily be shot. 3 years old with little use is a recepie for a sulfated battery.
Put it on a charger for a bit and see if it starts behaving as it should.
Or...
Charge it and then have an auto parts store load test it.
Or...
Just replace it.
2) i have heated grips - factory fitted left on last night, i assumed the ignition also cut the power to these -is that the case?
The grip kit features a series relay thet drops out when the ignition is switched off. The grip loose power when the switch is off... unless the relay is stuck.
3) and lastly is there a light on the factory heated grip switch?
No.
CLB is offline   Reply With Quote
Old 07-28-2009, 06:28 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
CLB you da man
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Sprint ST 1050 Heated Grips Masha Sprint Forum 25 09-07-2009 01:35 PM
Triumph heated grip throttle tube on 07 sprint st – wrong dimensions – was yours? shoen Sprint Forum 11 08-31-2009 11:51 PM
Help Please....03 Sprint RS Flat Battery shughp Sprint Forum 5 01-15-2007 04:45 PM
Gerbings Heated Clothing/ Sprint Battery? RickyT Sprint Forum 8 10-03-2006 01:20 PM
Heated grip switch template for '99-'04 Sprint ST adhamilton Sprint Forum 6 03-13-2006 09:35 PM
