Originally Posted by DTONA
Sounds like a better config' having 1 low and 3 high. Did you keep the original sockets for the high beam bulbs to plug in where the low beamers used to be? If so have you had any heat problems or was it just a case of running the extra wire accross and going for gold?
I didn't have to change bulbs or sockets - all three are the same anyway. I also didn't have to run extra wire.
There is a wiring harness directly under/behind the headlights which, on my '07, has the following wires: Black, Blue/Red, Blue/White, and Yellow. I cut the UR and UW, then connected one end of the UR to the other end of the UW and vice versa.
Before:
--UR--UR--
--UW--UW--
After:
--UR--UW--
--UW--UR--
