Old 06-06-2005   #1 (permalink)
Hi all,
I'll post the "drama" of a motorcycle shop that said they could fix the idle problem I was having at a later date. I have the tank off now, and cleaned the stepper motor and found and fixed various vacuum problems. I am ready to put the tank back on and I don't know what to connect the fuel pressure regulator hose to. I swear that there was not a hose hooked up to the fuel pressure regulator when I took it off. In fact, I didn't know what it was at the time, but thought it odd that there was nothing connected to it. I took off the two main gas lines, two breather hoses, and a wiring connector. there was nothing....I repeat...no hose hooked to the fuel pressure regulator! What does the fuel pressure regulator on the side of the tank connect to?
Thanks
Stephen
Old 06-06-2005   #2 (permalink)
Nevermind, I did a search of the archive and found the explanation. :razz:
Old 04-25-2008   #3 (permalink)
Newbie
Fuel Tank Pressure Regulator and breather hoses
I am having the same problem. WHere in the archives did you find the answer?
THanks,
marinerbiker is offline   Reply With Quote
Old 04-25-2008   #4 (permalink)
Favorite Bike: '00 Sprint RS 955i
pelon717's Avatar
Other Motorcycle: Suzuki DR125 Thumpette
THanks,
Use the search function and plug in 'fuel pressure regulator' or something similar. It sounds like most of the regulators don't need the hose hooked up. Mine never had anything connected to it as far as I can tell.
pelon717 is offline   Reply With Quote
Old 04-25-2008   #5 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
gee
Digging up ancient posts is fun!
marinerbiker the search thingo is a bit fiddly at times, it seems very specific to things like spelling etc.
DaveM
Old 04-25-2008   #6 (permalink)
Newbie
Breather hose with one way valve
Does the forward breather hose with a one way valve connect to the airbox? And should the valve open toward the tank? Does the rear breather hose just hang down to nowhere?
Just checking
Old 04-25-2008   #7 (permalink)
DaveM's Avatar
marinebiker
Hi mate I do not know the answer but you could help us help you by putting more info in your sig please
Please read the posting etiquette sticky.
cheers,
DaveM
fuel pressure regulator hose GJJ Sprint Forum 0 10-21-2007 10:48 PM
Where does the vaccum hose connect to from the fuel pressure regulator? TiggerTwo Tiger Workshop 3 04-22-2006 10:37 PM
Fuel pressure regulator hose connection? sixtysix Sprint Forum 3 06-20-2005 01:22 PM
Help Fuel pressure regulator hose 02 daytona 955i Daytona Deliberations 1 04-02-2005 12:13 AM
fuel regulator hose D Speed Triple Forum 1 05-04-2004 03:03 PM
