Originally Posted by baldybaldycrewman
Does anyone know where I will find this wiring?? I cant find it anywhere!
Stand at the front of the bike, facing the headlight.
Now squat down so that you can see under the headlight/fairing.
you`ll see where the upper and lower fairings meet, directly behind the lip of the joint on your left, you`ll find the GPS "econoseal" 2 wire power connector with blanking cap in place see
HERE and
HERE its a PIA to get out, but be patient. IF your going to use the GPS connector I suggest you order the adaptor cable see
HERE for the 1/2 price OEM cheaper alternative which is actually for the Tiger.
However, the GPS plug is a fused unswitched live which is why I installed a 10amp toggle switch with LED idiot light
HERE in the infill, just under the LHS clocks to switch it on/off
BTW, if you look on the opposite side under the fairing from the GPS connector you will find the 3 pin heated grips/accessory plug
where in the world are you?
