Old 06-05-2005   #1 (permalink)
I have a line on an Ohlins shock that was made for a 99-02 ST. Problem is I have an 03. So my question is..Will it fit? Anyone know? Thanks.
Jeff
JeffV is offline   Reply With Quote
Old 06-05-2005   #2 (permalink)
I wouldn't have thought that would be a problem as I believe the shock is the same on all the 1999-2004 ST's. I just checked the Jack Lilley online catalogue and they list the same WP rear shock for all 1999-2004 ST's.
To make 100% certain, I would think the easiest thing is to ring your Triumph dealer and ask them if the part number for the rear shock is the same for 99-02 as it is for 03. That should clinch it.
Bob
Nelson955 is offline   Reply With Quote
Old 06-05-2005   #3 (permalink)
The 2002 - 2004 Sprint STs are nearly identical. I can't imagine that they changed the shock. You should be fine.
[ This message was edited by: garry on 2005-06-05 18:45 ]
Pittsburgh RAT Pack
www.pghratpack.com
garry is offline   Reply With Quote
OHLINS SHOCK ON 955i? Brooksie Daytona Deliberations 14 10-10-2007 01:29 PM
Anyone know where I can get a rear Ohlins shock? slowkitty Hinckley Classic Triples 11 09-04-2007 05:02 PM
Ohlins shock for ST cyclesailor Sprint Forum 7 03-18-2007 05:48 AM
Ohlins Shock Install curefan Twins Technical Talk 0 10-02-2006 09:50 PM
Ohlins rear shock from 02 daytona fit 02 S3? kevf Speed Triple Forum 2 04-13-2005 09:18 AM
