Sprint electrical problem...Help! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-27-2009, 04:20 PM   #1 (permalink)
Question Sprint electrical problem...Help!
2004 RS, 3300 miles, never a problem until today. i turned on key and all the familiar noises and lights came on. then as soon as i pushed the starter everything went dead and i heard a click under seat. took off seat, checked all fuses, o.k. went to the library for the manual and after 30 minutes turned on the key, everything worked again but when i pushed starter, click all was dead. i do not know diddly about electricals, especially these new vehicles. think i will put a meter on the battery to check charge but that is about all i know to do. any help muchly appreciated. when it is low though, the starter clicks and lights work still. no clue.... j
jellero is offline   Reply With Quote
Old 06-27-2009, 04:55 PM   #2 (permalink)
Favourite Bike: 06 Sprint ST ABS red
iceman's Avatar
...... most likely a below par battery.
Any idea of the age or condition of it?
Be aware that putting a voltmeter on the battery might show you 12V or better but if it is getting tired that will quickly fall away under load.
A good place to start is charge the battery fully then get it load tested - by an auto electrician or battery shop.
Grant
iceman is offline   Reply With Quote
Old 06-27-2009, 05:08 PM   #3 (permalink)
battery is a year old, charged a week ago and again today, shows 12.6 volts. nothing happens when i turn the key on...no clicks, no instruments, fuel pump, nada. j
nevermind.... battery is bad. when i have charger on it i get noise, remove it and nothing. went out to check charger and it was on zero amps. been trying to get out to a bike rally all day, guess i missed it today. maybe this battery has a warranty? thanks, j
Electrical Problem 95 Sprint Toothpick T3 Sport / Touring Forum 6 10-02-2011 10:32 AM
Electrical Problem? MNTRIPLE T3 Sport / Touring Forum 6 06-21-2007 02:49 PM
2000 Sprint ST electrical problem. fueler955 Sprint Forum 9 04-02-2007 10:58 PM
help electrical problem? Tomsk RAT - United Kingdom 2 10-18-2006 06:52 AM
HELP!!!-electrical problem! BassNote Maintenance & Workshop Talk 3 06-23-2006 12:01 PM
