front brake discs - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsNew BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!
Old 06-27-2009, 07:28 AM   #1 (permalink)
front brake discs
Hi All
I have some play in the front brake discs on my 955 rs the play is between the disc and the carrier if the bike is rocked back and forth with the brake on you can hear a knocking sound from the disc any ideas can this play be taken out
Steve
steve1964 is offline   Reply With Quote
Old 06-27-2009, 12:10 PM   #2 (permalink)
Favourite Bike: 1974 Bonneville
roadduster2's Avatar
Other Motorcycle: 1973 Tiger
Extra Motorcycle: 2007 Suzuki VStrom 1000
steve1964 -
This is an IMO answer. The front discs are floating type, meaning they are supposed to give a little, or as you say, 'have play in them'. If you look at them they are attached to the rigid center mount by 'bobbins'. The fact you hear a 'knock' may be caused by them giving or floating on their 'bobbins' as you rock your bike back and forth.
This is a good thing as it tells you they are free and not bound up by anything causing them to bind up. Which can happen and when it does, it causes bad front brake action. Make sure your discs are freed up and do float, which as I say, IMO they working correctly. Your brakes are working as it was meant to by the designers.
roadduster2
roadduster2 is offline   Reply With Quote
Old 06-27-2009, 12:36 PM   #3 (permalink)
I understand that there should be a certain amount of float but 4 to 5 mm back and forth the MOT inspector over here will wet himself when he sees that much play does any one know what the tollerance should be
Old 06-27-2009, 01:34 PM   #4 (permalink)
steve1964
OK. 4 to 5mm of play in your rotor movement is not just a little.
So, post your year model of your bike, mileage, and this problem will have to go to some members who have more knowledge of this issue.
Hope you get it sorted out soon.
roadduster2
Old 06-28-2009, 12:50 PM   #5 (permalink)
Favourite Bike: My RED '02 Sprint ST
CharlieS's Avatar
Other Motorcycle: My Red '00 Sprint ST RIP
bump bump
---Charlie
Quick Turn Throttle Mod, Michelin PP2, CF TOR, Corbin Seat
CharlieS is online now   Reply With Quote
Old 06-28-2009, 07:34 PM   #6 (permalink)
oldndumb's Avatar
Hmmmm, 4 to 5 mm is grossly excessive.
I would not ride a bike in that condition.
Oldndumb
Caveat lector
oldndumb is online now   Reply With Quote
front brake discs currymonster Sprint Forum 27 02-28-2008 03:41 PM
Front brake discs paul502 Sprint Forum 12 08-22-2007 09:22 AM
Warped front brake discs on 955 models gaps113 Maintenance & Workshop Talk 4 07-18-2007 11:17 AM
Brake Discs Fatbob Tiger Chat 2 08-21-2006 07:32 AM
Brake Discs Triumph SuperSports 2 06-06-2004 05:36 PM
