As OnD said so very much depends on......everything that we don't know about you.
Here's a good link.
http://www.racetech.com/articles/Sus...AndSprings.htm
What you describe can be attributed to many things like tires, tire pressures, current settings etc., etc., etc.
For instance you mentioned front vagueness and the rear stepping out. What TP are you running? Too high a pressure can cause both of these symptoms as well as too stiff a compression especially in the rear.
Many confuse stiff with performance. Not so good on the street. Our local professional racer, two time AMA super bike champ, Daytona, currently Macao and IOMTT sets his front at 41mm sag.
Currently my setup is:
Misch. Pilot Road II's TP 34 front 36 rear
Front has a higher viscosity oil with 10ml more volume. 31.5 sag.
Rear is set at 26.5 sag.
I'm 200lbs fully kitted up and these setting I'm finding may be a bit stiff for the conditions I ride on and will probably loosen them up some.
Tires/tyres make a Huge difference in handling as well as the pressures.
Cranking in preload at the front is not a good idea either, this is why I opted for heavier oil and a bit more of it. With this I can run less preload and still keep the front planted and compliant.
Many are concerned about front end dive. Me less so, as long as I am not bottoming out. The more weight I have up there during cornering and braking the more I like it.
A lot of perceived front end problems can be traced to the rear. (I think you are too stiff back there either TP/preload or both) I'd also venture that you are running too much tp and or preload in the front too.
Here's a link to a thread showing my new PR2's. About all my riding in done in the mountains on fairly bad logging roads so keeping things planted is very important to me.
http://www.triumphrat.net/sprint-for...be-scarce.html
So far she's tracking straight in the low and high speed stuff up and down hill and handling the transitions quite well. I recently made some major changes in tires and setting both front and rear and still twiddling with it a bit.
Don
