2000 S/T rear wheel removal / Installation - Triumph Forum: Triumph Rat Motorcycle Forums
Old 06-26-2009, 10:03 AM   #1 (permalink)
Favourite Bike: 2000 Sprint S/T
rootff57's Avatar
I have a 2000 S/T and I need to replace the rear tire, I know taking it off is not a big problem but when I get ready to re-install I need some info on tourqing the brake calliper, rear bolt / nut for the the wheel, and chain adjustment????? any feed back would be greatly appreciated.... Thanks
rootff57 is offline   Reply With Quote
Old 06-26-2009, 10:56 PM   #2 (permalink)
Favourite Bike: 1974 Bonneville
roadduster2's Avatar
Other Motorcycle: 1973 Tiger
Extra Motorcycle: 2007 Suzuki VStrom 1000
rootff57 - You need a service manual. You will only need to remove the muffler and the big nut on the right side of the bike to
remove the wheel. Do not need to do anything to the brake and chain to remove the rear wheel. Don't forget to put a coupla two x eights or twelves under your center stand before starting so your wheel/tire will have more clearance for removal. Do you have side bags? You need to loosen up your bag mount on the right side as well. If you have a mc lift with a removable plate at the rear for wheel removal, then you've got it made.
FYI:
Tighten the big nut on right side to 146Nm, pay attention to the washers and their order of assembly under the Nut.
Rear Caliper retaining bolts tighten to 40Nm
Chain Adj from 1.4-1.6 inches/35-40 mm free play.
Do you have a handbook manual for the bike? It shows lots of info about maintaining the chain and whole bunch more.
Post up if you need more info.
roadduster2
roadduster2 is offline   Reply With Quote
Old 06-27-2009, 06:11 AM   #3 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Washers
Keep an eye on the direction the washers were in as they came of as well. One of them is dished, and has to go on the correct way round
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
REMOVAL OF REAR WHEEL BazzaST Sprint Forum 4 01-14-2007 05:13 PM
Rear Wheel Removal tcowjww Tiger Workshop (archive) 3 11-24-2006 07:46 PM
Rear wheel removal Anchorbend Twins Talk 6 04-12-2006 09:35 PM
Rear wheel removal feliz Twins Talk 3 01-13-2006 12:34 AM
Rear wheel removal Thunder_Forever Twins Talk 12 09-14-2005 11:28 AM
