BikeBandit
Old 06-02-2005   #1 (permalink)
Ok, I tried, according to manual (20 words of instruction) and I wasn't even close to managing it ...
how on earth do you easily use the center stand. In fact, how do you use it with difficulty!? I was in a garage with a smooth surface and fairly flat.
InParkSlope is offline   Reply With Quote
Old 06-02-2005   #2 (permalink)
face the bike squarly, push down with foot, not much lifting with hand but all push with foot. use your hand to guide the bike back. most important to face side of bike squarly.
"fast on the gas, late on the brake"
David Allen - RAT coordinator DCI RAT Pack
3144271204
davidallen@donelsoncycles.com
daveallen is offline   Reply With Quote
Old 06-02-2005   #3 (permalink)
Left hand on left bar (just to balance bike).
Right hand on passenger foot peg mount (the black triangle).
Right foot on center stand base holding it to floor.
Rock back pulling mostly with right hand on triangle.
It's easier without a full tank of gas. I'm 5'8, 160 and I haven't had much difficulty lofting it up there.
Airsick is offline   Reply With Quote
Old 06-02-2005   #4 (permalink)
Bike in neutral, ball of right foot on stand, right hand on flip-out handle, left on handlebars. step up on the right foot while pulling UP (not back) with the right hand. Then I click it back into first, whimper something about a hernia, and walk away.
I'm also 6'2" and around 250lbs... that helps.
(Wonders if that was too much info. Lighting up, He shrugs and hits submit anyway...)
CityRide is offline   Reply With Quote
Old 06-02-2005   #5 (permalink)
Left hand on the handlebar, right hand on the hand hold that's the top of the passenger footpeg bracket. Push the sidestand down with the right foot until it touches the ground. Lean the bike away slightly until you feel the other side of the side stand touch the ground. Push down with right foot while pulling up with right hand. It's more foot than hand and a momentum thing. You'll get used to it quickly.
brgsprint is offline   Reply With Quote
Old 06-02-2005   #6 (permalink)
ok thanks, with these tips i'll try again..
i wasn't sure what/why to foot-push down on once the center stand was touching the concrete, and yeah, its a full tank of gas, and panniers..
Old 06-02-2005   #7 (permalink)
encountered the same difficulty until i noticed i wasn't getting both legs of the centerstand touching the ground when trying to use it - was much easier thereafter.
g027605 is offline   Reply With Quote
Old 06-04-2005   #8 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
You will know when you have got it right because it won't be very difficult.
If you are busting your butt you havent got it right.
It is not about effort or strength but technique.
Cheers,
Dave
Old 06-04-2005   #9 (permalink)
omaz's Avatar
[quote]
On 2005-06-04 03:57, DaveM wrote:
"You will know when you have got it right because it won't be very difficult.
It is not about effort or strength but technique."
In that regard it's just like making love :wink:
[ This message was edited by: omaz on 2005-06-04 05:54 ]
omaz is offline   Reply With Quote
Old 06-04-2005   #10 (permalink)
thanks, last night, I got it up! not once, but twice!
:-D
center stand or rear wheel stand? SlackCat Speed Triple Forum 16 05-08-2006 02:53 PM
Kick Stand vs. Center Stand Tooth Modifications & Workshop Talk 9 10-19-2005 09:02 AM
Center stand and/or Swingarm stand or jack rprockey Hinckley Classic Triples 3 08-17-2005 06:21 AM
Paddock stand vs. center stand questions Solace Sprint Forum 6 04-01-2004 09:31 PM
Center stand and side stand wanted Sprint Forum 1 01-21-2004 08:38 PM
