Givi FZ726 top case installation ... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-21-2009, 02:20 PM   #1 (permalink)
It's been discussed a lot of what to purchase to fit a Givi box on the Triumph but nobody as said in all the dozens of thread if the install was a pain or if it was straight forward... Also, to confirm the stock panniers will fit with the FZ726 Givi bracket :|
I want to purchase the FZ726 Givi bracket and install it (I will follow the suggestion to buy longer screw found in another thread) but wondering if I will take numerous hours like my FZ1 to install the monokey rack on the '09 ST 1050 (took me 3 hours on the FZ1, had to cut plastic at a few places)...
So, i'll be joining the Triumph family soon, I should take delivery may 1st! Also, still thinking if I will go with the Triumph heated grips...
CoOlSlY is offline   Reply With Quote
Old 04-21-2009, 04:13 PM   #2 (permalink)
Favourite Bike: 08 Sprint 1050
321Go's Avatar
[QUOTE=CoOlSlY;1251452]It's been discussed a lot of what to purchase to fit a Givi box on the Triumph but nobody as said in all the dozens of thread if the install was a pain or if it was straight forward... Also, to confirm the stock panniers will fit with the FZ726 Givi bracket :|
I did, its quite straight forward, took me about an hour but i didnt rush. Get the longer bolts before installation!
08 Graphite 1050.
Alarm, Heated grips, Caulfield seat, Hugger and Fender extender, Skidmarx Double Bubble screen. R&G Crash Bungs, Givi top box and rack.
www.devilscrayon.co.uk/wp
321Go is offline   Reply With Quote
Old 04-21-2009, 04:30 PM   #3 (permalink)
[QUOTE=321Go;1251553]
The longer screw needed are the one that goes on the handle bar (4 of them) I guess and did the installation involved cutting anywhere?
Old 04-21-2009, 04:37 PM   #4 (permalink)
321Go's Avatar
[QUOTE=CoOlSlY;1251564]
Yep, the four that go into the grab rail, pictured below.
The only element that needed a stanley knife is that plastic cap that goes on the end of the support rail which goes under the bike and bolts to the inside of the footrest also pictured. Offer it up and you'll see what i mean, just needs a bit trimming of to make the bolt easier to screw in. Don't forget the Loctite on all bolts. You on the UK Oracle site too?
08 Graphite 1050.
Renntec Rack with Givi or other hard case - anyone done it? UJMrider Twins Talk 38 05-24-2010 07:54 PM
Advice on an 02 Sprint ST top rack for a Givi case? enos Sprint Forum 8 09-29-2008 10:38 AM
In case I go bye bye BILLYSIM Twins Technical Talk 8 04-03-2007 07:13 AM
just in case F.S. ctrhenry Speed Triple Forum 0 12-24-2006 06:18 PM
looking for givi side case rack for sprint rs masseyharris74 Sprint Forum 11 11-10-2004 09:52 PM
