Heavy Braking Shudder - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 04-20-2009, 10:05 PM   #1 (permalink)
Favourite Bike: 2002 Sprint ST
Other Motorcycle: 2009 Daytona 675
Question Heavy Braking Shudder
My `02 Sprint ST shudders under heavy braking,the faring and mirrors vibrate untill I release the front brakes.
The brake pads were replaced last spring. The rotors have .003-.004 TIR and visually look OK and are in tolerance of minimum thickness. The steering head bearings are to specs. and wheel bearings seem alright.
Light to moderate braking no vibration or shuddering. The bike does stop straight and true under light to heavy braking.
Suggestions,Help!
cyclesailor is offline   Reply With Quote
Old 04-20-2009, 10:27 PM   #2 (permalink)
Extra Motorcycle: 1979 Moto Morini 3 1/2 in
Try hosing down the bobbins that allow the rotor to move around some, you might have one or two that are sticking.
Old 04-20-2009, 10:44 PM   #3 (permalink)
Favourite Bike: 05 Sprint ST 1050
Sticks's Avatar
Extra Motorcycle: Wife's Bonneville America
Had similar issue I used my compressor to blow out some of the grit and then washed them with soap and water with a tooth brush.
OnD uses some thing to spin them to get them to float a little better I looked for his post a couple of months back but got side tracked
Sticks
Si hoc legere scis nimium eruditionis habes
Sticks is offline   Reply With Quote
Old 04-20-2009, 11:23 PM   #4 (permalink)
Favourite Bike: 2002 Sprint ST, BRG
Gatorman's Avatar
Other Motorcycle: 1978 Bonneville T140E
Extra Motorcycle: 2007 Suzuki DR 650
5 mm hex key fits
I use a spray of brake cleaner and rotate them a bit
Gatorman
"A sporting gentleman does not motor about at night" - J. Lucas
My Photo Album
Gatorman is offline   Reply With Quote
Old 04-21-2009, 03:37 AM   #5 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Spin the bobbin
Hi,
find an allen key that is a little smaller than the hole in a bobbin, wrap some gaffer tape around it until it fits with a little persuasion and use that to spin the bobbins as you spray brake and contact cleaner in it
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 04-21-2009, 04:06 AM   #6 (permalink)
Favourite Bike: '03 Sprint RS
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
all good advice. The bobbins get gummed up and it is part of my regular service.
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 04-21-2009, 04:18 AM   #7 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
I use Motul brake cleaner
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 04-21-2009, 05:38 AM   #8 (permalink)
Favourite Bike: 08 Sprint 1050
321Go's Avatar
idiot question time. What's a bobbin? Feels like mine need looking at if shuddering under front braking is a symptom. Thx.
08 Graphite 1050.
Alarm, Heated grips, Caulfield seat, Hugger and Fender extender, Skidmarx Double Bubble screen. R&G Crash Bungs, Givi top box and rack.
www.devilscrayon.co.uk/wp
321Go is offline   Reply With Quote
Old 04-21-2009, 06:25 AM   #9 (permalink)
DaveM's Avatar
321Go
Not an idiot question, it is not a technical term (well I don't think it is).
The bobbins are the circular thingamajigs on the rotor that connect it to the rotor frame doohicky.
On the Sprint there are about 10 of them and they are approximately 20mm in diameter with about an 8mm hole in the centre.
They allow the discs to move about a bit. They are meant to be free but get gummed up with brake dust and road crap.
When they cannot allow movement they can cause the vibration previously described through the bars.
This is my non technical explanation, the only kind I know how
DaveM
My current album;
Old 04-21-2009, 06:36 AM   #10 (permalink)
321Go's Avatar
Thx a lot. I assume that any brake cleaner should be applied sparingly to each 'bobbin' whilst loosening up.
A job for this afternoon i think. Cheers DaveM.
08 Graphite 1050.
It just makes me shudder... jrelloway Daytona675 Forum 9 08-05-2008 12:45 PM
Brake Shudder nmendham Sprint Forum 12 07-15-2008 12:55 PM
shudder fatric Twins Technical Talk 3 06-06-2008 12:31 PM
Front end shudder Andrew1965 Sprint Forum 9 08-10-2005 10:55 AM
Front end shudder - help! Speed Triple Forum 10 08-21-2004 09:08 PM
