Chain adjustment - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-19-2009, 04:45 PM   #1 (permalink)
Favourite Bike: 2011 Sprint GT
KaptainRat's Avatar
Other Motorcycle: Yamaha XJ 650 (Restoring)
Extra Motorcycle: Bultaco Sherpa T 360
Chain adjustment
Hi I'm a new member, a great site. Have read the new member sticky.
I just read about the new chain adjustment ( free_movement) in the maintenance for your Sprint forum which stated that the free movement is 27-37mm while the bike is on the side stand. I was wondering if this amounts to be the same as 35-40mm while the bike is on centre stand (as per manual) as the the back is of the ground with no weight on it.
Thanks
KaptainRat is offline   Reply With Quote
Old 04-19-2009, 04:54 PM   #2 (permalink)
Favourite Bike: '08 Sprint ST
Other Motorcycle: '70 Husq 360cross
Thanks
Unless you found something else-
I was going on the exact same assumption as you. Re-read the manual on Pg.#79, the first paragraph under the safety warning is:
Park the motorcycle on the sidestand.
They just seemed to open up the spread a smidgen'.
Bruce C is online now   Reply With Quote
Old 04-19-2009, 11:52 PM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Hi and welcome to the forum KaptainRat
Thanks you fro saving my typing fingers and readiong the forum stickies already
Enjoy the forum
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 04-20-2009, 12:45 AM   #4 (permalink)
Favourite Bike: '05 Sprint ST
Other Motorcycle: '72 Kaw H2, '83 GPz550
Extra Motorcycle: 05 MINI Cooper S
I was the OP on the updated measurement. It came up because I was confused about the descrepancy between the text (sidestand) and the illustration, and 'checking for the tight/loose section of chain' which would seem to make more sense when the bike is on the center stand. After discussions with a local dealer and Triumph USA sidestand is correct (both original and updated spec).
If I remember correctly my chain slack was at 40 on the centerstand and needed to be tightened to make 35 on the sidestand; so I would say the 35-40 is not appropriate for the centerstand. It runs much smoother now with less slack.
FYI, I did put it on the centerstand to find the tight spot and I suppose now that I have it correct on the sidestand I (or you) could put it on the centerstand to find the 'on centerstand' dimension.
COBlue is offline   Reply With Quote
Old 04-20-2009, 01:28 AM   #5 (permalink)
KaptainRat's Avatar
Thanks, next time I have adjusted the chain I will put it on it's centerstand and check the the amount of slack. As it is a lot easier to find the tight spot it's on the centerstand.
Old 04-20-2009, 01:34 PM   #6 (permalink)
Favourite Bike: 2000 Sprint
skos's Avatar
Other Motorcycle: 04 Road King
Extra Motorcycle: 07 YZ450F
As I understand it, chain slack is the total movement of the chain. Usually measured in the middle.
I measure the distance you push the chain all the way down and then measure the distance from that point to where it stops.
Also keep in mind to make sure your wheel is tracking correctly.
Always Pay it Forward!
skos is offline   Reply With Quote
Chain adjustment? My chain is too slack, cant adjust. roadkill Speed Triple Forum 12 06-17-2010 05:30 PM
Chain adjustment after suspension adjustment? Mochissmo Speed Triple Forum 1 10-13-2008 10:33 PM
chain adjustment Zeef Twins Technical Talk 5 06-01-2008 11:11 AM
Chain Adjustment jixaw Triumph SuperSports 8 06-20-2007 11:03 PM
Chain Adjustment boocat Tiger Workshop (archive) 3 05-17-2007 09:35 AM
