rear axle shaft removal - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearHonda PowersportsMotorcycle.comMotorcycle.com Classifieds!
Old 02-21-2009, 07:04 PM   #1 (permalink)
Favourite Bike: 1967 Vespa Alpha
2007 Sprint ST ABS. I reviewed a number of posts at this site about greasing the rear axle bearings. A bit confusing but it appears there are sealed ball bearings but then also needle bearings in the hub that are accessible. I'm having difficulty removing the rear axle. I removed the wheel, brake caliper, and sprocket drive assembly. According to my tech manual (pg 12.18) the axle shaft should be able to be pulled out from the swingarm/hub assembly. I've tried tapping and light/moderate pounding on the left side but get absolutely no movement, hate to pound with any force here. Anyway a number of folks appear to have greased their rear wheel bearings, have you found the axle shaft difficult to extract? I'm assuming i can readily access the needle bearings for greasing once i remove the shaft? If not I'll just button it up and leave as is, but i thought i would see if anyone else had a problem extracting the axle on a late model abs sprint.
danall is offline   Reply With Quote
Old 02-22-2009, 04:45 AM   #2 (permalink)
Favourite Bike: Sprint ST 1050
Nope, mine just slid out after removing the sprocket assemby staked nut from the shaft, and pulling the whole thing off the splined shaft. Does it turn freely by hand ? the needle roller bearing acts directly on the axle shaft, and I believe this is the part that can fail and chew the shaft.
Pcdabbler is offline   Reply With Quote
Old 02-22-2009, 10:24 AM   #3 (permalink)
Favourite Bike: '08 Sprint ST
Other Motorcycle: '70 Husq 360cross
Danall
I'm new to the new Triumphs, but old at bike maintenance, so you can take or leave my advice.
As far as removing that shaft, after you go by the book to remove all pieces/parts. Put a block of wood against the axle and hit it ONLY with a 1-2lb. plastic coated, dead blow hammer. If it don't move then, take it to the shop.
Bruce C is offline   Reply With Quote
Old 02-22-2009, 12:29 PM   #4 (permalink)
Thanks guys
Yup, have the spocket assembly off the splined shaft, pounded moderately with an 18oz hammer on a wood block on the end, no movement whatsoever. According to the manual it should just pull out as yours did...or at the most with some moderate persuasion. Looks like i may have bearings fused to the shaft?...reckon i will reassemble and take it in to the shop.
Old 02-22-2009, 12:34 PM   #5 (permalink)
How many miles do you have on the bike and do you ride/store it in the rain?
Old 02-22-2009, 01:10 PM   #6 (permalink)
DEcosse's Avatar
That - as everyone, including yourself, says - should just pull out.
It appears that the axle is seized in the bearings.
I don't see any means of applying a puller for this scenario - I've racked my brain trying to think of how to devise one & coming up empty.
You're going to have to get more force behind it appears - the only thing you can likely damage would be the bearings - assuming you are replacing those anyway. Have the nut over the end of the shaft to protect it and using your wooden block try a bigger hammer.
Try to get some penetrating oil at least on the left side bearing/axle - right will be impossible to access of course
T'Rat.net BOTM November 2009
Old 02-22-2009, 03:33 PM   #7 (permalink)
thanks Decosse
In response to a few questions, yes the axle currently turns but somewhat stiffly, is not locked up. Purchased the bike new late in fall of 2007, now has just under 12,000 miles. Is garaged when not ridden, dry climate here, but i have ridden 3-4 times in extended rain. Never use a pressure washer on the bike.
I also tried to see how a wheel puller could be used...no luck. I think i will assemble and take it to the dealer as I'm hoping this might be covered under warranty if in fact i have seized bearings.
I have tried some moderately hard pounding on an oak block and could see absolutely no movement so I just think I'll let the Triumph shop deal with it although i prefer to do all my own maintenance and repair. other option of course is bathe it in penetrating oil and use a really big mall and beat the **** out of it.
Old 02-22-2009, 03:44 PM   #8 (permalink)
Well, you are under the 24mo. of in-service limit and the rear drive bearing is not to be serviced until 12K. So with those parameters it's a warranty case for sure. Hope you didn't bugger things up too much.
The last option of just beating on the thing is the point when you tweak the swingarm and really foul things.
Old 02-23-2009, 01:20 PM   #9 (permalink)
Oh dear. It's at the bogey mileage... 12,000 miles sems a common thread to the more recent RWB break ups I've been reading about.
There's one here
Old 02-23-2009, 02:07 PM   #10 (permalink)
oldndumb's Avatar
BTW, some relube the bearing without removing it from the eccentric housing. That is not the best practice. the bearing should be removed, cleaned and repacked with the correct amount of grease. Do not spin the bearing with air pressure while cleaning it. That will destroy the bearing and forever identify you as a !
The bearing is held in position by a large snap ring which can be difficult to remove without a good snap ring plier. The small, rinky dink snap ring pliers that come with the Builder Bob tool sets will not work.
Oldndumb
Caveat lector
Rear axle removal + fun crash piccys jeffster Sprint Forum 16 06-27-2008 12:37 AM
Gear shifter shaft removal dat Twins Technical Talk 3 06-11-2007 10:41 PM
Selector Shaft Removal bwolfgti Speed Triple Forum 0 11-08-2006 10:18 AM
Axle Nut Cover Removal? fwhite Speed Triple Forum 6 09-09-2004 10:52 AM
Removal of balance shaft? KenT140D Hinckley Classic Triples 8 08-09-2004 04:40 PM
