02-16-2009, 05:12 PM
Starting problem
Sometimes, increasingly often, when I press the starter switch on my '06 Sprint ST, absolutely nothing happens, although the lights come on on the instrument panel as soon as I switch on the key. When this problem occurs, I switch the key off and then back on and then it usually starts as it should. This problem started after my bike was out of service for a month while some body panels were being repaired (non-crash damage). During that time, I kept it on the battery tender every other day. (Tender is shared with another bike) I also took the opportunity while the fairing was off to replace all 6 relay holders. That involved disconnecting and re-connecting each relay.
Does anyone have an idea what might be going on? Could I need a new battery? This one has been in sevice since June '06.
Thank you,
Bruce O'Reilly
02-16-2009, 05:22 PM
SuperSport Favourite Bike: Sprint RS,Black,04
Posts: 1,391 Other Motorcycle: That one Extra Motorcycle: Yorkie and Silky WOOF!!
Are you doing...
Ignition> Panel Lights> Wait about 6 seconds for the fuel pump to prime> Starter button?
Or is nothing happening, IE No starter turnover, no 'clicks' ? when you press the button??
Battery connexions REALLY tight?
Chocolate Food of the Gods!!!!!!
02-16-2009, 06:05 PM
Clarification
I am waiting the 6 seconds or so after switching on the key. The fuel pump primes, the gauges calibrate, and then nothing, or then, something on the occasions when it works. No clicks when it doesn''t work. Battery connections are clean and tight.
02-16-2009, 06:26 PM
Immoderate Moderator
Site Supporter SOTP Vintage Series Favourite Bike: '04 Sprint RS
Posts: 7,936 Other Motorcycle: Dead '96 Trident in NYC Extra Motorcycle: '77/'82 Suzuki GS550/650
Seems an awfully new bike for this, but those symptoms are quite consistent with corroded contacts inside the starter switch. Might be worth (Carefully! Spring-loaded!) taking the switch assembly apart & cleaning the contacts.
Cheers, HTH,
-Kit
02-16-2009, 06:39 PM
Site Supporter Formula Extreme Favourite Bike: Sprint ST 1050
Clutch switch. Give it a maul around next time it doesn't start and try again
02-16-2009, 08:02 PM
Powerbike Favourite Bike: 1050 Sprint ST
Posts: 327 Other Motorcycle: Kawa 636 (track), CRF230F Extra Motorcycle: previous:CB750CR,GSXR1100
Had the same problem with my previous bike, a Honda VFR... looks like a Starter relay problem... changed mine and started like a charm after that..
Good luck with resolving this problem... I ha-te electrical problems...
02-27-2009, 02:08 AM
It's the clutch switch
The problem is the clutch switch. If the transmission is in neutral, there is never a problem. In gear, with the clutch pulled in, the problem is intermittent. Jiggling the switch will make it start. Now my question is, how does one remove the clutch switch for replacement or repair? The service manual shows nothing on this topic and I don''t want to force things.
- Bruce O'Reilly
