I believe that part actually seals the cam cover to the cylinder head mid-well.
There is an upgraded part number for the 1050 coil seal.
The original seal let moisture into the well.
The new seal part number "T1291511" includes a cap that covers the well lip visible in the link Caddy posted.
I have seen two different coil arrangements for 955's. One coil is bolted on while the other (Caddy's link) is press-fit.
If your coils are press-fit, the upgraded 1050 part might fit. The best way to tell would be to drop by a dealer that has a 1050 coil in stock and see if it fits. If it does and the coil body is the same dimension as yours order a set of seals.
Originally Posted by caddydaddy
