Installing crash bungs, can't get a wrench in there to hold the nut - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsMotorcycle.com
Old 01-01-2009, 11:13 PM   #1 (permalink)
Favourite Bike: 2000 Sprint ST
Other Motorcycle: 1999 Sportster Sport
I am installing R&G sliders on a 2000 Sprint.
When you turn the bolt, the nut on the back side just spins, so you need to get a wrench back there to hold it. I got the right one on and am working on the left side, and finding that there not much room to work.
On thought was I MIGHT be able to get a short 17mm wrench on it (if I had one). Another thought was maybe a socket, a universal and super long extension might work (to go out through the other side of the bike).
Anyway before buying additional tools, I thought I would ask how others might have solved the problem. Thanks
Basic research is what you are doing when you don't know what you are doing...
Razzoo is offline   Reply With Quote
Old 01-02-2009, 06:12 AM   #2 (permalink)
Favourite Bike: 04 Sprint St
Other Motorcycle: Suzuki RGV250 track bike
Extra Motorcycle: Fantic 201
I used a long extension (possibly 2 of them), a universal joint adaptor and the socket, but it's a little awkward getting the socket on as it drops down when you try to line it up. It helps having someone else with small hands at the nut end to help guide it on, then hold the bar on it's flats with an adjustable to torque it up.
Cheers, Swamp.
Swampy is offline   Reply With Quote
Old 01-02-2009, 07:14 AM   #3 (permalink)
Favourite Bike: Not Sure Anymore
22856's Avatar
Did mine a few weeks back...It's tight and fiddly (said the actress to the bishop). But with patience and persistence it can be done, even with my chubby hands.
Thing I was worried about is that the wrench connection to the back nut while I was doing up the bolt...would flick around and put a hole in the radiator...something to watch out for.
Good luck mate.
22856 is offline   Reply With Quote
Old 01-02-2009, 08:49 AM   #4 (permalink)
oldndumb's Avatar
Razzoo, I hope your aversion to buying tools does not include torque wrenches, because that is one of the critical fastener installations on the Sprint.
Oldndumb
Caveat lector
Old 01-03-2009, 12:00 PM   #5 (permalink)
Favourite Bike: '08 ST graphite
Other Motorcycle: '07 Ducati 1098S
A stubby 17mm combination wrench worked for me. I have the GSG frame sliders from British Customs.
elevens is offline   Reply With Quote
Old 01-03-2009, 04:39 PM   #6 (permalink)
Favourite Bike: '00 RS
johnO's Avatar
i had no trouble installing sky king sliders on my RS.it took longer to replace the fairings than the sliders.only 2 nuts and 2 bolts,but perhaps a different mounting point ?
I'm tired of thinking,so i'll just do some wishful drinking......
johnO is offline   Reply With Quote
Old 01-04-2009, 03:52 PM   #7 (permalink)
Favourite Bike: Sprint 955 2001 - Blue
Other Motorcycle: HD 883 Sportster Custom
Is there much point putting sliders on a 2001 ST? I had a quick look on the slider site and there's just 1 slider goes on each site in a gap, is that really going to do much?
ztolley is offline   Reply With Quote
Old 01-04-2009, 04:23 PM   #8 (permalink)
oldndumb's Avatar
The answer to your question is subjective because "going to do much?" is vague.
If we knew what your expectations were, it would be easier to answer your question.
I can tell you that they will not prevent all damages, and you may get scratches if the bike is dropped. I can also tell you that they can prevent some major ($$$) damages, and your bike will not spin like a top on the pavement if it goes down as described in another thread.
Oldndumb
Caveat lector
Old 01-04-2009, 04:28 PM   #9 (permalink)
I guess the answer is: yes, no, depends. It could reduce possible damage but isn't going to wave a magic wand and cause my bike to hover...
Old 01-04-2009, 11:38 PM   #10 (permalink)
Thanks for the responses.
I got the sliders installed, and used the two extension + universal method.
If the sliders protect the fairings in a drop from a dead stop I will be happy.
I added a ratcheting screwdriver with hex bits to the bikes kit, and am getting pretty good/quick at removing and replacing the fairings.
While I had the fairing off, I replaced the right headlight bulb with a brighter bulb, however I find the clip that keeps the headlight bulb in is very aggravating to work with.
I had a tab brake off of the left fairing (I think it was already cracked) and I was able to fix it with Plastex, so far I am impressed with this product.
Crash bungs Doc007 Speed Triple Forum 8 01-18-2007 10:03 PM
Crash Bungs Alpha Hinckley Classic Triples 3 09-05-2006 01:16 PM
R&G crash bungs RedMick Sprint Forum 0 02-26-2006 03:17 PM
Crash Bungs Sprint Forum 5 04-12-2005 01:06 AM
r & G crash bungs littonlad Sprint Forum 3 11-23-2004 08:09 PM
