Check Engine Light - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-30-2008, 02:42 PM   #1 (permalink)
Favourite Bike: 2001 Sprint St 955i
alii1959's Avatar
Check Engine Light
Well, the saga of my fueling system leaks continues. I finally managed to figure out what the problem was, a loose hose (didn't look loose, didn't seem loose....). Buttoned it all back up and whaddaya know....check engine light won't go out. AAAARRRRGGGhhh. Is there anyway to reset the bloody thing?? I rechecked the connections today all seems to be well. I checked all of the wiring to make sure that all of the connections were tight....they were. I cannot find a place in the Haynes manual that talks about resetting the check engine light. Any help would be appreciated.
alii1959 is offline   Reply With Quote
Old 12-30-2008, 02:54 PM   #2 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
Clearing Check Engine Light
Hi alii1959
If you have cured the thing that was causing the engine light to come on, then after 3 complete heat cycles; that is from cold to Fan on (I think it is fan on rather than operating temp) 3 times, then the light should go out.
If you are comfortable that you have got the thing that caused the light, then go ride. You'll do three heat cycles in 3 rides!
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 12-30-2008, 03:07 PM   #3 (permalink)
alii1959's Avatar
I knew it was something like that. Just couldn't remember. I had removed the battery, to have it checked, a few weeks ago and the light came on then. It subsequently went out, but I couldn't remember the sequence. Thanks.....if it doesn't go out.....I guess something else has cropped up.
Old 12-30-2008, 10:33 PM   #4 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
On 955i's it is definitely when the fan comes on and DO NOT touch the throttle.
3 heat cycles like this and the Sagem ECU has reset itself.
See link to an old thread of mine on this subject;
http://www.triumphrat.net/sprint-forum/65847-reset-all-settings-on-ecu-on-sagem-sprint.html
cheers,
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 12-31-2008, 12:24 AM   #5 (permalink)
Favourite Bike: Claret '08 Rocket III
JRCollings's Avatar
Erm, your link is a dud Dave.
JRCollings is offline   Reply With Quote
Old 12-31-2008, 01:27 AM   #6 (permalink)
DaveM's Avatar
Oops thanks I will fix that at once!
DaveM
My current album;
Old 12-31-2008, 01:28 AM   #7 (permalink)
DaveM's Avatar
Ok
try this for size!
http://www.triumphrat.net/sprint-for...em-sprint.html
That had better work!
DaveM
My current album;
Old 12-31-2008, 04:39 AM   #8 (permalink)
RexxyPup's Avatar
Reset the ECU is not Turn out the light
Dave,
thanks for sorting out the fan on temp thing, but if you just want to turn the engine check light out, then it is simply three heat cycles, you can ride it.... I have done it!
Your instructions are for the ECU to relearn idle fuel settings, tps, IACV etc.
Rexx
Old Albums
New Albums
Old 12-31-2008, 05:40 AM   #9 (permalink)
DaveM's Avatar
You are right Rex I was just getting carried away with myself, you know once I heard my own voice I couldn't stop!
cheers,
DaveM
My current album;
Old 01-01-2009, 07:08 PM   #10 (permalink)
alii1959's Avatar
Yea!!!...it cycled off. Thanks for all the help.
s4 check engine light spdfour Triumph SuperSports 6 08-17-2008 11:58 PM
check engine light PROMOD1385 Speed Triple Forum 1 03-18-2007 09:10 PM
check engine light Quietsouls Maintenance & Workshop Talk 6 12-24-2006 10:33 AM
Why is my check engine light on? fivehundo Daytona Deliberations 4 07-30-2006 02:55 PM
Check engine light Speed Triple Forum 1 07-02-2004 02:19 PM
