Sprint 1050 Valve Cover - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-29-2008, 05:25 PM   #1 (permalink)
Favourite Bike: Sprint ST 1050
deltablues's Avatar
I have an oil leak on the left side of my engine. My ride is an '06 Sprint ST 1050.
I have searched the forum...saw the post about the stator cover...but this leak is up above that.
Took it by the dealer here in Little Rock. They seem to think it is just the valve cover. Said they have not seen 1050's leak oil much.
The bike runs fine otherwise. Probably a simple fix...and my brother has already joked about it now being a 'real' Triumph.
deltablues is offline   Reply With Quote
Old 12-29-2008, 10:58 PM   #2 (permalink)
Favourite Bike: 08 Pacific Blue Sprint ST
caddydaddy's Avatar
Was your bike built on a Friday afternoon?
How many miles on it? I hope it's a simple fix for you!
2008 Sprint ST 1050 ABS - Pacific Blue
TOR muffler and tune, 18T front sprocket, Triumph flip-up Aero screen, K&N air filter, Powerbronze Hugger and RAM mounted GPS!
caddydaddy is online now   Reply With Quote
Old 12-30-2008, 03:59 PM   #3 (permalink)
Favourite Bike: 06 Sprint ST
Other Motorcycle: BMW F650GS
I had an oil leak on the left side apparently from the valve cover... dealer replaced the valve cover seal under warranty and no further problems.
msst1050 is offline   Reply With Quote
Old 12-30-2008, 04:07 PM   #4 (permalink)
Favourite Bike: 2006 Triumph Sprint ST
ricster's Avatar
+1 here too. Mine was the left side within 6 months of purchase...replaced v/c gasket...no issues. When they are doing that though..I would have them torque the stator and clutch covers..they do due to tend to leak from those nuts getting loose.
Save an animal....adopt and give someone less fortunate a home
ricster is offline   Reply With Quote
Old 12-30-2008, 05:20 PM   #5 (permalink)
oldndumb's Avatar
Valve covers are one of the few gaskets on the 1050 that requires gasket sealant. Do not apply it to the entire gasket; just on the four half moon rubber plugs on each outboard side.
When checking torque on the engine cover fasteners, loosen them first and then re-torque them. Checking torque without first loosening them will cause an over torque condition which could easily lead to stripped threads.
Oldndumb
Caveat lector
Old 12-30-2008, 05:24 PM   #6 (permalink)
Favourite Bike: Sprint 1050
ralphus's Avatar
Originally Posted by oldndumb View Post
Valve covers are one of the few gaskets on the 1050 that requires gasket sealant. Do not use it on the entire gasket; just on the four half moon rubber plugs on each outboard side.
+1. Did just as the Oldnwise one suggested above when I did my valve clearances several months ago, no leaks since.
05 Caspian Blue Sprint 1050
ralphus is offline   Reply With Quote
Old 12-30-2008, 10:45 PM   #7 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Yes Ralphus he should change his name to oldnwise 'cos he ain't that old and he certainly isn't dumb!
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 12-31-2008, 05:15 AM   #8 (permalink)
Favourite Bike: 09 graphite Sprint ST abs
Lazarus Long's Avatar
Other Motorcycle: yeah right
DaveM
But Ond works so well in Swedish (means evil)
Lazarus Long is offline   Reply With Quote
Old 12-31-2008, 05:44 AM   #9 (permalink)
DaveM's Avatar
Oh well in that case that settles it OND it is!:
DaveM
My current album;
Old 12-31-2008, 11:14 AM   #10 (permalink)
oldndumb's Avatar
Busted!
Oldndumb
Caveat lector
Cam/Valve Cover oil leak krautfed Triumph SuperSports 7 08-23-2007 02:27 PM
Valve cover BoFax Triumph SuperSports 7 07-24-2007 04:26 PM
Bagster tank cover and bag on a 1050 Sprint ST JTXR Sprint Forum 6 07-22-2007 11:43 AM
Cam/valve cover removal Triple_Rider Speed Triple Forum 12 02-07-2007 08:31 AM
T-100 valve cover MotoSayle Twins Talk 4 11-10-2005 09:42 PM
