Grumpy Trumpy - Triumph Forum: Triumph Rat Motorcycle Forums
Honda Powersports New BonnevilleSportbikeTrackGearMotorcycle.com Classifieds!Ontario Tourism
Old 10-23-2008, 01:03 AM   #1 (permalink)
Newbie
Favourite Bike: Still searching
Other Motorcycle: '97' T509 Speed Triple
Extra Motorcycle: Yamaha XT660X
Unhappy Grumpy Trumpy
Hi all,
I'm new to this awesome site and I'm hoping that beginners luck coupled with some good brains may help me with a really annoying issue i have with my 97 T509.
the symptoms are:
Burbling Idle - its just doesn't sound right, pops and sounds spluttery.
small throttle openings upon Accelerating and decelerating sound like its missing making it jolty in traffic, very annoying... when slowing down in gear (engine braking) it sounds normal until about 2k rpm's at which point it pops, surges forward and begins to stutter as mentioned above, occasionally it back fires near the 3k rpm's mark especially if you have a small throttle opening during the engine braking towards a corner following a few back fires it becomes sluggish in response.
Hesitant throttle when 'blipping'
Full open throttle openings - when opening the throttle wide open in 6th at low revs or under similar 'hard' working situations, it splutters, stumbles, pops and bangs and as soon as its past 3-4k rpm's its off like a rocket!
OK so i tried..
New Inlet manifold gasket.
New stepper motor.
New Vacuum pipes to the stepper (IACV) assembly.
New Crank Sensor, correctly adjusted.
New plugs.
new temp sensor.
Checked Coil packs, all read the same ohms, all have the same dwell reading whilst running.
Checked Valve clearances. - all spot on.
Throttle body sync 4 or 5 times!
Co level adjusted to the book, then up and down 1% using a gas analyser. - no changes, just gets richer.
tried multiple ECU engine maps using Tuneboy.
Checked Airbox for cracks and holes, and that all pipes are snug.
Checked each engine/speed sensor, ohms and for deterioration.
cleaned injectors
changed fuel filter, checked tank internal fuel pipes for tight connections.
cleaned one way ball valves located in the vacuum tubes.
Ran fuel system cleaner
checked exhaust joints.
Always use the best fuel I can get
Oh and the Plugs are the correct colour!
But still... the problem exists..........
Am i just missing somthing simple here? these bikes can't run like this from the factory???!
Its got to be something to do with the low speed running system, but I'm stumped.. interestingly the bike idles when the throttle body sync gauge is connected, should't it stall?? thats my only clue..!
Any ideas?
cheers in advance for any help with this deeply disturbing issue..
stiple is offline   Reply With Quote
Old 10-23-2008, 02:04 AM   #2 (permalink)
Favourite Bike: '98 Thunderbird Sport
denny's Avatar
Other Motorcycle: '06 Husqvarna TE 610
Extra Motorcycle: '95 TBird - Project
Compression test?
Cheers,Denny
denny is online now   Reply With Quote
Old 10-23-2008, 08:54 PM   #3 (permalink)
Newbie
Cheers Denny,
Forgot to mention that I had checked that too, got good readings..
thanks for the thought though.
Old 10-23-2008, 09:45 PM   #4 (permalink)
cave1's Avatar
What exhaust and what number Triumph map? I had some of your symptoms running the stock pipe with an older (1999 issue) dealer-installed map. So with the Tuneboy, did you switch between the latest available Triumph maps: 9852, 9853, 9854? There just don't seem to be a lot of custom tunes out there for the T509...
cave1
97 T509 Speed Triple, 77 BMW R100S
"Never argue with a fool, onlookers may not be able to tell the difference." Mark Twain
cave1 is offline   Reply With Quote
Old 10-23-2008, 10:21 PM   #5 (permalink)
OKcarburetor's Avatar
leaky injector?
"I never vote for anyone. I always vote against."
W.C. Fields
OKcarburetor is offline   Reply With Quote
If you had to replace your Trumpy ruscook Biker Hang-Out 58 03-28-2008 10:21 PM
Grumpy ? affecting your posts and emails ? Tbirdnz Biker Hang-Out 4 10-25-2007 12:51 PM
Wed Feb 28 Trumpy PuttPutt on the Putty or Bells Mid-Week Madness ruscook Sprint Forum 80 03-04-2007 06:36 AM
Wed Feb 28 Trumpy PuttPutt on the Putty or Bells Mid-Week Madness ruscook Speed Triple Forum 19 02-10-2007 04:42 PM
modern Trumpy wiring connecters amberale Maintenance & Workshop Talk 3 04-11-2006 05:45 AM
