Motorcycle.comBikeBandit
Old 04-17-2005   #1 (permalink)
i wondering if anyone has any imput as to what brand of slider (if any?) they might have on their S3? does the triple's bolt size compare to any other make of motorcycle (any of the japanese brands?) any imput on this is greatly appreciated, thanks. :???:
speedboy is offline   Reply With Quote
Old 04-17-2005   #2 (permalink)
I got mine from skyking and I luckily haven't had to test them out yet.
I'm considering buying the extended sliders for the front to further protect the bike in case it should ever slide or tip and ensure there is something which would stick out further than the radiator should the bike fall over. Plus, they're the same sliders the 'On One Wheel' wheelie school uses.
They also have tail section sliders, but thats about all they'll protect, your tail section plastic. Though, they don't stick out very far at all and look a bit odd.
Old 04-18-2005   #3 (permalink)
nyburner's Avatar
kulka,
where have you found extended sliders for the S3? i've been looking for a set...
nyburner is offline   Reply With Quote
Old 04-18-2005   #4 (permalink)
Guys
I have these. My dealer recommends them too. I'm not sure exactly what you mean by "extended" but the set I have go quite high up on the engine mounting bolt. Works OK unless you have long legs.
http://www.rg-racing.com/
Roland is offline   Reply With Quote
Old 04-18-2005   #5 (permalink)
SKYKING PRODUCTS
Frame Sliders (Top Front )
[Triumph Speed Triple (1997-2004)]
Code: Item-116
Price: $85.00
Those bolt onto the far front mounts behind the radiator.
Old 04-18-2005   #6 (permalink)
nyburner's Avatar
anyone lay it down on the right side? my biggest fear is busting open the oil cooler....
Old 04-18-2005   #7 (permalink)
nyburner's Avatar
Old 04-18-2005   #8 (permalink)
R&G!!
Tried the very pretty, but mechanically flawed LSL ones first, then went for cool, hard functionality.
Plus point with R&Gs is that if you have long legs, you can use them as knee rests when braking hard and not load up the bars by locking your elbows!!
Stunt demons apparently stand on them!!!
Have a look at my album : Volume 1 p6 (I think)
Does not play well with others!!!
Windchill is offline   Reply With Quote
Old 04-18-2005   #9 (permalink)
R&G!!
Sliders BillT Speed Triple Forum 29 09-12-2007 08:32 PM
Sliders.... kwajazz Speed Triple Forum 3 10-11-2006 10:20 AM
Sliders 4philthy Sprint Forum 4 05-08-2006 11:30 PM
Rear Spindle Sliders and Front Fork Sliders FelixLeiter Speed Triple Forum 9 01-20-2006 11:17 PM
Jack Lilley Frame Sliders...rear sliders too??? SR1 Sprint Forum 4 11-26-2005 08:01 AM
