Strange starting issue - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.comSportbikeTrackGearNew Bonneville
Old 10-20-2008, 07:18 AM   #1 (permalink)
Sparti's Avatar
It's been a while sinse i last posted here.
I hope I explain this clearly and some wise one amongst you can point me in the right direction.
Over the last 2 months I have been having a weird starting problem. Everything works as it should when turning the key (lights, sounds etc) but on a semi regular basis the starter turns over but no hint of the engine even starting. The cranking starts to slow after a while and on a few occasions I would get a loud clank noise from somewhere in the engine. The first time I heard this I thought I’d broken something internally.
Like I said this has happen quite a few times and on one occasion my battery gave the impression it had no charge. I stuck it on charge and also tested the battery on the multi-meter and all looked fine. Still it happened again the day I went to the MotoGP and decided at that point that my battery was faulty so I got a new one (DEKA battery).
All good until it happened again yesterday. I turned it off and on again it then it fired up fine.
Once the bike was running I placed the multi meter on the battery and at tick over it read 13.90’sh. If I gave the throttle a squirt or kept it at constant revs the multi meter would read 13.30’sh
Engine wise the only thing I have done in the last 2 months is install a Zard slip on and install a tuneboy tune for a low mount exhaust with no SAI. Not sure if this is the problem but has anyone had a similar problem once installing a low mount tune to their bike?
Please help – I’m stumped
Sparti is offline   Reply With Quote
Old 10-21-2008, 12:41 AM   #2 (permalink)
Favourite Bike: 05' 1050 S3
G'day mate!
I think your triple is experiencing the exact same symptoms mine did -- bad sprag clutch. The sprag clutch is incorporated as a safety mechanism insuring torque can only be applied from the electric motor to the engine and not vice versa (e.g. when the engine is actually running). Unfortunately the pre-07 models seem to be made of tinsel.
See my thread:
http://www.triumphrat.net/speed-trip...n-t-start.html
On the upside, you are in luck as most triumph dealers, at least on our side of the pacific, will replace the sprag clutch as a good-will gesture to 07+ spec. Also if you've been experiencing long cranking issues (2+ turns) prior to this, the update seems to fix that too.
'05 Black S3
slacker is offline   Reply With Quote
Old 10-21-2008, 05:04 AM   #3 (permalink)
Sparti's Avatar
Thanks slacker - that's very helpful. I'll call Triumph Aus tomorrow and see what they say.
Sparti
Old 10-21-2008, 08:55 AM   #4 (permalink)
I had a similar issue too, though only when the cold weather was with us and I never heard the clunk that others describe and associate with the sprag...
It went down to Peter Stevens twice for assessment and they told me a guru from Triumph was on the case, directing them...
They replaced my sprag clutch the second time I put it in. It took me 2 days before I had the same issue again, BUT it hasn't happened since - I put it down to warmer weather... hope you have a nice n easy experience with a definite fix!!
Funny thing is, it started happening maybe a month or so after I installed my CRM exhausts and applied the Tuneboy non-SAI tune... in the CRM instructions it did say SOMEthing about not always firing on the first go... who knows what's at play for me, but I wanted to put this reply up in case it gives any more insight...
Cheers,
Herb
Herbus is offline   Reply With Quote
Old 10-21-2008, 07:50 PM   #5 (permalink)
Sparti's Avatar
Herbus, where abouts in Melb are you based?
I saw a white speedy the other day with CRM's on it just outside of Eltham while on the way to work - was that you? There would not be many Speedy's in Melb with CRM's so it's a good possibility it was.
Sparti
Old 10-23-2008, 09:26 AM   #6 (permalink)
That would probably be me mate, I'm in Montmorency - you're nearby? Small world
Old 10-23-2008, 09:36 AM   #7 (permalink)
Sparti's Avatar
Incredible
I live off of Silver street Eltham. I've been riding speedy in the area for the last three years so you may have seen me around.
Here's a pic of her with her latest mods
If you're up for it - would be good to catch up for a ride. Send me a pm or email. Eitherway i would like to catch up to see and hear what the CRM's are like. Not seen them in the flesh before.
Old 10-23-2008, 10:03 AM   #8 (permalink)
Favourite Bike: 2000 Speed Triple
Beautiful bike.
The new(er)triples just look hard. I love them.
Tripped1 is offline   Reply With Quote
Old 10-23-2008, 12:33 PM   #9 (permalink)
It's a shame they stopped using that blue. My orange is no doubt faster, but I'd give it up for that color.
'61 Clubman's Gold Star, '76 R90S, '03 CBR600RR (track bike), '04 599 Hornet, '08 Speed Triple
Chip is offline   Reply With Quote
Strange Starting Issue TBSstunta Hinckley Classic Triples 6 06-10-2008 02:16 PM
Strange LCD display issue voodoo_chile Speed Triple Forum 6 10-31-2007 07:03 PM
strange starting problem twinrider Tiger Workshop (archive) 4 09-13-2006 11:01 AM
Strange exhaust issue.... markfly Hinckley Classic Triples 7 10-13-2004 02:45 PM
Starting issue ToddZimardo Maintenance & Workshop Talk 2 07-29-2004 06:06 AM
