New S3 owner - engine sound question - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-19-2008, 12:36 AM   #1 (permalink)
Newbie
Favourite Bike: 2001 Speed Triple
skullnbones's Avatar
Other Motorcycle: 2007 KLX250
I just bought an '01 S3 and this is my first encounter with the triple engine. The power delivery is smooth during acceleration but at idle or constant speed, the engine sounds sort of unbalanced. I'm not sure if there is a problem or if this is just a characteristic of the triple cylinder engine. My bike has a Two Brothers exhaust and power commander, has a nice growl, strong pull and fast acceleration.
Am I just hyper-sensitive because I just bought the bike, or is this normal for the triple?
Bodily injury received from an act of stupidity is not an accident....it's consequence.
skullnbones is offline   Reply With Quote
Old 10-19-2008, 01:27 AM   #2 (permalink)
Diego's Avatar
I'm not sure what "unbalanced" means, but if you are talking about an unsteadiness of speed at idle, it could be a fuel system matter... anything from throttle bodies not being in perfect balance, to an air leak in the system, a bad oxygen sensor (if the system is still operating in closed loop mode), or the Power Commander simply not being set up as precisely at idle as it is at operating conditions. None of these should be a major concern, but if you can clarify the symptoms a bit, probably someone here can narrow down the possibilities for you.
John
Old 10-19-2008, 04:46 AM   #3 (permalink)
Favourite Bike: 2003 Sprint ST
Extra Motorcycle: 1400 intruder
I have a 2001 Daytona 955i and it has a very mechanical sound to it but that is normal for the early 955 engines
Is that what You are refering to?
flyinloww is offline   Reply With Quote
Old 10-19-2008, 12:28 PM   #4 (permalink)
Favourite Bike: '01 Speed Triple
The triple sounds like a bag of hammers, but it's normal. Just wear earplugs and it sounds better.
Speed3 is offline   Reply With Quote
Old 10-19-2008, 01:20 PM   #5 (permalink)
cave1's Avatar
What Speed3 said. The sound kind of grows on you...
cave1
97 T509 Speed Triple, 77 BMW R100S
"Never argue with a fool, onlookers may not be able to tell the difference." Mark Twain
cave1 is offline   Reply With Quote
engine sound Litfuse Speed Triple Forum 5 06-18-2007 10:49 AM
engine sound differences: Bonnie vs Scrambler twinrider Twins Talk 5 04-14-2007 01:22 PM
Ticking sound from engine BonnyGuy Twins Technical Talk 13 10-15-2006 02:06 AM
Engine Noise (with video/sound clip) odium Speed Triple Forum 4 06-12-2006 01:18 AM
Bonneville Engine - Ticking Sound Archimedes Twins Talk 7 08-02-2005 11:13 AM
